98 jdm h22a won't crank over?? why?, how?? can it be fixed?,
Old Nov 4, 2008 | 05:46 AM
duceducecord's Avatar
Default 98 jdm h22a won't crank over?? why?, how?? can it be fixed?,
The situation is my 98 5th with a jdm h22a will sometimesnot want to crank over. I have full power to the battery just changed starter. It happened yesterday it didn't want to start after I turned it off so lucky I was on a hill so I poped the clutch n it fired up. Some sources say that u should hit the starter to free a sticky something. But its brand new.... I don't know wat else to try. Should I take my car to get my chargin system check for free? And also could it be the ignition switch cas I head about it around that it could be the cas. I read this one site listing the recalls for honda and my 98 lude was in that list but the recal began in 2002 so I duno if I can still get it changed out 4 free.
Old Nov 4, 2008 | 06:13 AM
SKDRCR's Avatar
Default Re: 98 jdm h22a won't crank over?? why?, how?? can it be fixed?, (duceducecord)
When it doesn't crank over do you hear the starter click at all or is it
absolutely nothing?
Check your connections at at the starter, also check your battery connections.
If you can still hear it clicking, you might just have a defective starter.
Call the dealer on your Ignition switch issue, there might be a recall on it.
BTW: They quit making lude's in 01, there is definately a recall on this issue,
just give them your vin number, if they say no, check another dealer to verify it.
Old Nov 4, 2008 | 11:32 AM
Default Re: 98 jdm h22a won't crank over?? why?, how?? can it be fixed?, (SKDRCR)
Ok cool but I have the jdm h22a will that make a diffrence at the dealer and I think I hear the fuel pump power up but that's about it. I had to mess with the key buy turnin it on n off fir a while then the car started up n it hasn't died yet. But there is a recell on the ignition switch. Will that cause the starter not to crank or make n e noises. What's werid is when it happened I wasn't able to start it with the key but I was able to pop the clutch n start the car I duno this has me puzzled thanks for the feed back
Old Nov 4, 2008 | 02:20 PM
AndyD's Avatar
Yes, a bad ignition switch can cause exactly what you're experiencing.
Old Nov 6, 2008 | 02:25 PM
Default Re: 98 jdm h22a won't crank over?? why?, how?? can it be fixed?, (AndyD)
I think it was the starter cas I took it to honda and the recall for the ignition switch they replaced it already. But now im getting p0450 and p0453 codes and when the cel light comes on the car starts to bog out until I restart it the my idle jumps up n down for a bit. But when I drive its fine I duno.....
Old Nov 6, 2008 | 02:46 PM
98vtec's Avatar
moderator emeritus
what do those codes represent?
Old Nov 8, 2008 | 01:54 PM
Default Re: 98 jdm h22a won't crank over?? why?, how?? can it be fixed?, (98vtec)
P0450 is "Evaporative Emission Control System Pressure Sensor Malfunction".P0453 is "Evaporative Emission Control System Pressure Sensor High Input". but i sloved by plugging up a loose plug but now im getting P0505 which is "Idle Control System Malfunction" i think its the IACV tho.. what do you guys think
gilhurt
Honda CR-V & Element
May 16, 2019 06:10 AM
bigbluwall
11
May 25, 2015 08:15 AM
S!K TEG
Oct 16, 2014 04:59 AM
98civd16y8
Jun 28, 2014 06:57 AM
H22Honda98
Oct 13, 2007 08:43 AM
