Interesting Formulas You Might Like
Old Jul 30, 2002 | 11:01 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Interesting Formulas You Might Like
I Math
Formulas
Rod ratio= Center line to center line length of the rod / Stroke
1.74 or greater is most desirable for racing
Air temperature = every 7 degrees F >60 degrees F= 1 % loss in
horsepower
CI displacement = bore x bore =__ x .7854 =__ x stroke: divide by .061
for CC x number of cylinders
Compression ratio: Volume of the cylinder, piston dish and head dish and
headgasket from top to bottom of the stroke, divided by the head, piston,
and headgasket volume or:
bore(in.) x bore(in.) =__ x .7854 =__ x stroke (in.) =__/ .061=__cc of
cylinder + (head cc +piston cc + headgasket cc) / (head cc+ piston
cc+headgasket cc) = compression ratio
Piston speed in fpm= stroke (in.)x rpm/ 6
Piston speed desired= 5800 fpm or less
Horsepower= rpm x torque/5252
Altitude effects on HP: every 1000 ft + = 3% loss in HP
Engine CFM approximation: RPM x C.I. displacement / 3456 = approximate
CFM: Example, Civic 1.6, 97 C.I x 7200 RPM = 698400 / 3456 = 202
approximated CFM
Calculation for CFM from HP: HP x .5 (BSFC) = __lb. per hour fuel x 13.2
air/fuel ratio = __lb. air per hour / 60 minutes per hour = __ lb. per
minute / .07 = CFM. Example: Civic 1.6, 127 hp x .5 = 63.5 lb. per hour
fuel x 13.2 air fuel ratio = 838.2 lb. air per hour / 60 minutes per hour
= 13.97 lb. per minute / .07 conversion to CFM = 199 CFM
Injector flow increase vs. fuel pressure increase:The square root of the
new fuel pressure / original fuel pressure x the original fuel injector
flow =__ new flow in lb. per hour: Example 1.6 liter Civic with Auxiliary
Fuel Pressure Regulator: Take the square root of 70 psi(new rail
pressure) / 40 (original rail pressure) = 1.3229 x 24 lb. per hour =
31.75 new flow rate in lb. per hour
Injector sizing for horsepower: Desired HP x .5 (BSFC)=__ lb. of fuel
required for desired HP / __amount of injectors =__lb. per injector x
__duty cycle = __lb. per hour per injector
Fuel pump or injector horsepower capability = Pounds per hour@fuel
pressure desired x 2 =__ HP capability
Gallons per hour to Pounds per hour= __ gallons x 6=__Lbs per hour
Enjoy!
Ryan
Old Jul 30, 2002 | 11:03 AM
whatREDLINE's Avatar
Default Re: Interesting Formulas You Might Like (vtecvoodoo)
thanks, but my head hurts now...
Old Jul 30, 2002 | 11:07 AM
neveronlines2k's Avatar
Default Re: Interesting Formulas You Might Like (whatREDLINE)
Wow looks like you had some time to kill there. Thanks for the info
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Interesting Formulas You Might Like (stuckatworksi)
cut n paste ownz
Old Jul 30, 2002 | 11:12 AM
DragII's Avatar
25 Year Member
awesome...copy, and pasted
Old Jul 30, 2002 | 11:15 AM
joeseph's Avatar
vtecvoodo, you rock, thanks for all the formulas (i also math)
I don't think a single production honda engine has a rod ratio above 1.65, but I could be wrong (just going of the top of my head)
Old Jul 30, 2002 | 11:17 AM
DragII's Avatar
25 Year Member
Default Re: Interesting Formulas You Might Like (jcnfh)
the B16 is 1.75
Old Jul 30, 2002 | 11:18 AM
.nate's Avatar
rock! great stuff!
Old Jul 30, 2002 | 11:24 AM
joeseph's Avatar
Default Re: Interesting Formulas You Might Like (DragII-Sellout)
the B16 is 1.75
my bad
b16a2=1.74
h22=1.49
h23=1.58
b18c=1.58
b18b=1.54
d16=1.52
d15=1.59
Old Jul 30, 2002 | 11:26 AM
IM ALL BOB's Avatar
you know what's funny ryan.. there is no Honda Book that conrtains any of this formulas.. yet I have a VW engine builders book that has all of that info plus more.. guess it just shows how serious the other Car fanatics are over the Honda guys so to say oh well good info for all the guys here to read thru..I love working at the library I get all the best engine books =P
Old Jul 30, 2002 | 11:27 AM
DragII's Avatar
25 Year Member
Default Re: Interesting Formulas You Might Like (IMALLBOB)
they have to be more serious..their pos's are built in mexico...so you pretty much have to start from scratch
Old Jul 30, 2002 | 11:28 AM
vtecvoodoo's Avatar
Future Texas Boy
haha
Old Jul 30, 2002 | 07:34 PM
IM ALL BOB's Avatar
hahah yes sad to say VWs and domestics are all Made in Mexico =x
Old Jul 30, 2002 | 10:25 PM
Mista Bone's Avatar
D Tranny Guru
D15Z and D15B VTEC = 1.62
Old Jul 31, 2002 | 12:15 AM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: Interesting Formulas You Might Like (Mista Bone)
What about the F20c1?
Old Jul 31, 2002 | 12:34 AM
VTEC
Guest
Posts: n/a
Default Re: Interesting Formulas You Might Like (PatrickEwing)
My favorite formula is 1.
Formula 1
Old Jul 31, 2002 | 12:46 AM
B18C-EJ1
Guest
Posts: n/a
B16B = 1.86
Old Jul 31, 2002 | 12:47 AM
joeseph's Avatar
Default Re: Interesting Formulas You Might Like (B18C-EJ1)
c27a4 =2.04
Old Jul 31, 2002 | 12:52 AM
joeseph's Avatar
Default Re: Interesting Formulas You Might Like (Blue-Civic-Hybrid)
isn't it just f20c?
Any one know its rod length (stroke is 84mm right?)
Old Nov 8, 2002 | 07:36 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Interesting Formulas You Might Like (joseph h)
Doing some k series homework for something I might build and thought I`d bump this. Very useful info
Old Nov 8, 2002 | 09:27 PM
Evs-One's Avatar
Solbros Owns Me
on the compression ratio...all the dimensions have to be of the same family. You have bore in inches, when it should be converted to centimeters so it's the same as cc of the cc and so forth..I just skimmed over so I might just be seeing things
Old Nov 8, 2002 | 09:28 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Interesting Formulas You Might Like (Emerica)
I stand corrected, it was converted to CC's!!
Old Nov 8, 2002 | 09:32 PM
91hatchcivic's Avatar
damn im confused , o well
btw// math sucks
Old Nov 9, 2002 | 03:31 AM
KoRn_vIRuZ's Avatar
Default Re: Interesting Formulas You Might Like (91hatchcivic)
Simple, but cool stuff that everyone should know.
