Suspension & Brakes Theory, alignment, spring rates....
Del sol Big brake kit
Old Nov 3, 2008 | 08:07 PM
shifter0037's Avatar
Default Del sol Big brake kit
i bought a 1993 si del sol with a tenzo big brake kit on it which is ricey(i know). needed brakes and the only pads that i could find were duralast ones from autozone(only place open at the time) so i got the gold cereamic ones part number DG617, which took them and i over an hour to find pads to match. i searched but couldn't find any info on the tenzo big brake kit calipers. wondering if any one knows which front calipers i have and if i can get smaller rotors with my current calipers to run 15's or should i just go back to OEM setup. any info would be great.
Old Nov 4, 2008 | 06:34 PM
_BEN_'s Avatar
Default Re: Del sol Big brake kit (shifter0037)
Are the calipers aftermarket or are they oem calipers with a spacer to accomodate the larger disk?
If you have the oem calipers with spacer set up, all you need is to remove the spacer and re-attach the caliper with the oem bolts. And of course swap out the big tenzo disks with some oem sized blanks.
Old Nov 5, 2008 | 07:46 AM
Default Re: Del sol Big brake kit (_BEN_)
there not stock sol calipers, stock pads wouldn't fit. im thinking that there gsr or similar calipers.
the_racerx
Suspension & Brakes
Aug 25, 2013 11:44 PM
4ghatch
May 28, 2007 10:36 AM
rudeman85
Jul 13, 2004 05:55 PM
