Question about suspension
hey everyone, well i found a set of skunk2 full coilovers for cheat. But the coilovers is for a EG and i have a 97 EK, is there any one using eg suspension on a ek?? any weird noise, or does it ride weird??
The only concern that you should have is that you will need to use some sort of spacer on the lower mounting bolts for the rear dampers. The '92-95 rear lower mounting fork is wider than the '96-00 fork, so you must have something to take up the space between the damper and its bushing (a handful of washers will do the trick).
Other than that, they are essentially the same.
madsnoopy714
Suspension & Brakes
Apr 10, 2012 05:13 AM
pancake
Apr 11, 2008 09:38 PM
.::miLan
Suspension & Brakes
Nov 15, 2005 05:31 PM
.::miLan
Nov 8, 2005 08:44 PM
ogawa_jiei
Mar 28, 2004 02:36 PM
