Car is having trouble starting up, please help
Old Nov 3, 2008 | 04:22 PM
Xxcivic99xX's Avatar
Default Car is having trouble starting up, please help
i have a 99 civic ex auto.
I am having trouble starting it up. I wanted to ask for some help. The car has always ran great. it has 160K miles. Car is stock.
The trouble started two nights ago. I was at my GFs house and they have 5 gallon gas tank inside the garage. The gasoline in it has been there for a months, i think like 5 months. Well we poured about a gallon into their Santa fe and the rest into my civic. I had about half a tank of gas before i added any gas. Their Santa Fe wouldnt start up the next day, it woudl just crank. it eventually started and it smoked for a second(whitish smoke). Then I checked my car to see if it had the same problem. It cranked up just fine and then i turned it off; Later that night I started it up and ran fine for a few seconds until I put it in reverse and the car shut off. Ever since, the car hasnt been able to start up.
I am thinking something was wrong with the gas and it screwed up my fuel pump or something in the fuel system. But i am unsure, it just cranks and cranks but doesnt start up....like you're trying to start the car with low gas. Today I put a cheveron fuel system cleaner in to see if it would help but it still doesnt start up.
anyone have any ideas.
thanks a lot for the help guys!
Old Nov 5, 2008 | 07:33 AM
HitF8's Avatar
Default Re: Car is having trouble starting up, please help (Xxcivic99xX)
try replacing the fuel filter, could have got clogged. or if the gas had a mixture of oil/gas that might cause it not to start. good luck
Old Nov 5, 2008 | 05:05 PM
Default Re: Car is having trouble starting up, please help (HitF8)
thanks for the help
bump for anymore ideas
thanks!
Old Nov 9, 2008 | 03:34 AM
bump for more answers
Old Nov 11, 2008 | 09:56 AM
vtec_4800's Avatar
check ur fuel filter cause when u run the car low on gas or put shitty gas in it will clog it instantly
mjhtmh
Honda Civic (2001 - 2005)
10
Oct 26, 2006 05:12 AM
LvN
Jun 9, 2006 11:31 AM
LvN
Jun 6, 2006 12:21 PM
pr0digy1
May 8, 2002 09:08 AM
