92vx hatchback 95 gsr swap. wont rev up past 3rpms. help
Old Jul 30, 2002 | 10:13 AM
jdmekcivic2eg's Avatar
Default 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help
has anyone had this problem please help. thanks
Old Jul 30, 2002 | 10:58 AM
BryanSprinkel's Avatar
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (jdmeg6turbo)
Better not be your car, fool.
My offer just went to $500 cash...
Chump
Old Jul 30, 2002 | 11:11 AM
SuperCivic's Avatar
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (BryanSprinkel)
Chump
i think it's his old car..haha..they can't even get the stupid thing running.
Old Jul 30, 2002 | 11:16 AM
Kalokohan's Avatar
New User
This is your old white hatch Champ? Who did the swap for the kid?
Old Jul 30, 2002 | 11:34 AM
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (Guardson3r3)
some guy did... ha.. anyways.. help this kid out so i can give him a good azzzzz whippin this sunday...
Old Jul 30, 2002 | 11:42 AM
Kalokohan's Avatar
New User
Wish I could but I'm brain dead right now from this heat. Hey, did you try the IAB thing I told you yet? You could give an even better azz whooping with an extra 15% of low end torque.
Old Jul 30, 2002 | 12:35 PM
owen_the_soyboy's Avatar
YES. I had the same problem in my 92 CX with a 94 GSR swap. It wouldnt go anywhere above 3000 rpm, then I found an iguana under the accellerator pedal, so we removed the iguana and the car feels great now! damn iguanas!
Old Jul 30, 2002 | 12:37 PM
SuperCivic's Avatar
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (owen_the_soyboy)
92vx hatchback 95 gsr swap. wont rev up past 3rpms YES. I had the same problem in my 92 CX with a 94 GSR swap. It wouldnt go anywhere above 3000 rpm, then I found an iguana under the accellerator pedal, so we removed the iguana and the car feels great now! damn iguanas!
lol!!!!
i wonder if they put all four spark plugs in.
Old Jul 31, 2002 | 04:48 AM
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (SuperCivic)
damn.. some people have a lot of free time.. haha..
Old Jul 31, 2002 | 04:57 AM
SuperCivic's Avatar
does it idle smooth, but just won't rev past 3K?
Old Jul 31, 2002 | 08:44 AM
gsrroots's Avatar
its the knock sensor in the back of the motor ...its not hookrd up right ...mine did the same thing in my gsr when i swapped motors..just swap the two wires and it should work if not i dont know whats wrong
Old Jul 31, 2002 | 09:09 AM
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (gsrroots)
thanks man for the tip.. ill try that..
Old Jul 31, 2002 | 01:37 PM
SpooN Man's Avatar
What code. You know the check engine light kinda hard to tell what is wrong if you don't have a map.
Old Aug 1, 2002 | 03:53 PM
SuperCivic's Avatar
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (SpooN Man)
update: we tried a known good ecu..car will rev all the way to 8K. noticed however that VTEC was not activating. checked oil. oil was tar black and halfway up the dipstick. we drained about 3 1/2 quarts of the black crap out so that the oil level was just above full. haha..8 quarts is too much. i can't imagine anyone spending 3500 on a GSR swap and not changing the oil when they were done. oh well. we took the car out again and still no VTEC. the car is a VX and previously had a d16z6 w/ working vtec..my question is, do any wires need to be added to the harness in order for vtec to activate? i felt under the manifold and the knock sensor is plugged into something..what i don't know, but it's plugged in. i forgot to pull the hazard fuse and reset the ecu before we took it out..the bastards don't have a working bulb in the CEL on the cluster..how ghetto is that? any help is appreciated!
Old Aug 7, 2002 | 10:14 PM
did you run the wire for the knock sensor?
8 quarts of oil...
Old Aug 8, 2002 | 12:29 AM
boostinb18's Avatar
id test the vtec solenoid.....try on another car or get a ohm meter.
good luck!
Old Aug 8, 2002 | 06:06 PM
kwil666's Avatar
Default Re: 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help (boostinb18)
id say replace the bulb and read the codes.
keith
[Modified by kwil666, 3:07 AM 8/9/2002]
siasinohio
Aug 21, 2008 08:58 AM
dzminiz
Nov 17, 2004 07:34 AM
rwcdrums
Oct 23, 2004 05:30 AM
blackhyb
Sep 20, 2003 11:38 PM
