cams not spinning
Old Nov 3, 2008 | 02:05 PM
flipdrift's Avatar
Default cams not spinning
so before i take of all these belts i wanna know for sure its the timing belt problem . starter is working all other belts are spinning but the timing belt is not spinning and the car just wont start i thought it was the dizzy but i took off the head cover and the cams are not spinning so i think its the timing belt broke but it still feel tight on top or something behind that shield but before i remove all that any thoughts?
Modified by flipdrift at 3:16 PM 11/3/2008
Old Nov 3, 2008 | 02:07 PM
sleepingciv's Avatar
Default Re: cams not spinning (flipdrift)
sounds like a busted belt to me.
Old Nov 3, 2008 | 02:12 PM
VTEC_PRODUCTION's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipdrift &raquo;</TD></TR><TR><TD CLASS="quote">so before i take of all these belts i wanna know for sure its the timing belt problem . starter is working all other belts are spinning but the timing belt is not spinning and the car just wont start i thought it was the dizzy but i took off the head cover and the cams are not spinning so i think its the timing belt or something behind that shield but before i remove all that and thoughts?</TD></TR></TABLE>
AND bent valves for sure now...dumb
Old Nov 3, 2008 | 02:14 PM
Default Re: cams not spinning (VTEC_PRODUCTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
AND bent valves for sure now...dumb </TD></TR></TABLE>Ya i was gonna edit my post and say stop trying to start it cause your messing up your valves.
Old Nov 3, 2008 | 02:18 PM
flipdrift's Avatar
Default Re: cams not spinning (sleepingciv)
thanks didnt know now i do thank you but should the belt still feel tight on top?
Old Nov 3, 2008 | 02:21 PM
ya it should be, is yours?
Old Nov 3, 2008 | 03:06 PM
flipdrift's Avatar
yea its still tight on top
Old Nov 3, 2008 | 03:12 PM
If its tight it could be bound up on top. and busted on the bottom.
The starter will turn the crank and it will turn the crank pully moving the other belts.
Old Nov 3, 2008 | 03:42 PM
teggy71's Avatar
might have broken a pulley or something.. but if the bottom side of your engine is spinning, and the top isnt, im afraid you may have squashed valves.. very good reason to get a vtec head.. but maybe a busted crank? i would think crank or pulley. hopefully not a crank
Old Nov 3, 2008 | 05:12 PM
Default Re: cams not spinning (teggy71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy71 &raquo;</TD></TR><TR><TD CLASS="quote">might have broken a pulley or something.. but if the bottom side of your engine is spinning, and the top isnt, im afraid you may have squashed valves.. very good reason to get a vtec head.. but maybe a busted crank? i would think crank or pulley. hopefully not a crank </TD></TR></TABLE>
holy ****. stop talking. obviously you have no experience when it comes to engines. re evaluate what you say before you post something like that again.
Old Nov 3, 2008 | 09:54 PM
CompanyFlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy71 &raquo;</TD></TR><TR><TD CLASS="quote">very good reason to get a vtec head.. but maybe a busted crank? i would think crank or pulley. hopefully not a crank </TD></TR></TABLE>
Two things:
1. Whats this supposed good reason?
2. What makes you think the crank is damaged?
IMO it could be the belt if it isn't a tensioner but theres only one way to find out.
stevenDAtegra
May 7, 2009 09:56 PM
valve79
Dec 29, 2004 03:20 AM
NotUrAvgSi
Apr 14, 2004 02:33 PM
InTeGrA B18b1
Aug 20, 2003 07:57 AM
420aNT
May 5, 2003 08:08 AM
