I need ur expert advice on this wheels fitment WRD CHEVLON DE MESH 4X100 16X9 +15 205/45/16
This is going on a 99 honda civic hatchback that has h&r race springs. So am wondering if I would have some trouble rubbing.. The wheels once again is WRD CHEVLON DE MESH 4X100 16X9 +28 16X9 +15
205/45/16. That's for the help lookin to buy some rims tried of my stock hx and need something nice so it could calm me down on speeding and beating on the car thanks again
That's the right tire size for your car, but those wheels are MUCH too wide and that size tire should NOT be mounted on a wheel that wide. (It is UNSAFE and just a bad idea all around.) 205/45-16 tires are usually approved for mounting only on rims 6.5-7.5 inches wide. I recommend 16x7 rims.
You can make it work.
You're going to need a good amount of camber in the back, and a pull of the fenders....it's def possible. I did an EK recently, and was surprised by how much room there was in the fender wells.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielg »</TD></TR><TR><TD CLASS="quote">You can make it work.</TD></TR></TABLE>
NOT SAFELY. When you mount tires on wheels that are wider than those approved, stress and heat can build up in the sidewalls, leading to tire failure. DON'T DO IT.
lazyvietboi
96
Jan 26, 2002 08:08 AM
