Hood won't latch closd - Cable release is loose.
Old Nov 3, 2008 | 04:53 AM
k-series's Avatar
Default Hood won't latch closd - Cable release is loose.
95 Si Hatch
The hood won't get the final "lock" when you close it. It's like it's perma 'popped', so it won't fly up, but it's not down all the way.
I'm about to start tearing the car down because I'm having it painted and was planning on re-routing the cable release anyway, but I wanted to see if anyone else has had this issue before and if I needed to replace anything. (Can't tell by looking at the latch.)
I did a few searches and most were broken cables with the hood stuck down...
Any help would be great, thanks!
Steve
Old Nov 3, 2008 | 05:11 AM
Black96Hatch's Avatar
Default Re: Hood won't latch closd - Cable release is loose. (k-series)
best suggestion is to take the latch off the car a spray th shi t out of it with wd40 or if u can get to a parts washer clean it with that for like 45 min i had the same problem on my ej6 trust me clean the hell out of it and make sure when ur cleaning it to move all the parts and make sure they move semi freely also try moving the latch up or down to see where u need it to completely lock
Old Nov 3, 2008 | 05:32 AM
k-series's Avatar
Default Re: Hood won't latch closd - Cable release is loose. (Black96Hatch)
Ok, great! Thanks for the info!
Steve
efjones9
Jan 11, 2009 01:04 PM
boostedhks
Jul 24, 2008 07:45 PM
EJ1Dream
Jan 3, 2007 07:04 PM
blueaccord94
Mar 26, 2005 07:53 PM
jlv55
Oct 8, 2004 04:05 PM
