90 Integra LS 4 Dr White to Black smoke?
Old Nov 2, 2008 | 10:54 PM
818blue818's Avatar
Default 90 Integra LS 4 Dr White to Black smoke?
my car was throwing white smoke. After the oil change it turned black.
it also has straight pipe i was told that might be a cause but not 100 percent sure.
Just would like to know why does it smoke that color and if i need to fix something what and how? thanks
Old Nov 2, 2008 | 11:12 PM
majinsoftware's Avatar
well white smoke is from water getting into the engine, Head gasket maybe?
If its white for the first few mins of running its normally acceptable from water getting up the exhaust.
Is it black or blue the other smoke.
Black is normally running to rich,
where blueish is oil getting burnt.
Normally from the valve seals and piston rings on Hondas.
If it happened straight after a oil change you may need to run thicker oil.
Check if there's water in your oil or oil in you water and warm the car up with radiator cap off and check if its bubbling.
Old Nov 2, 2008 | 11:15 PM
818blue818's Avatar
Default Re: (majinsoftware)
when i took out the oil there was about 3 qts and tehn after the oil change i put in 4 before it was white and funny gas smell now its black and different smell but im guessing its ok just running rich right?
oldschoollove
53
Jan 25, 2011 04:37 PM
Teamdiesel
12
Apr 25, 2006 06:21 AM
1990civicsi
Aug 8, 2004 06:33 PM
egracer44
23
Oct 3, 2003 06:25 AM
Malice
Mar 5, 2002 04:07 PM
