help: jdm b16a engine guru..identify this sensor please
Old Jul 30, 2002 | 08:41 AM
dxlst's Avatar
Default help: jdm b16a engine guru..identify this sensor please
my brother is doing his own swap and got stuck..any info will be appreciated
will the msd cap work with jdm b16a to replace the butterfly/ rotor?
and whats that broken green sensor? is that a crank sensor?
thanks in advance.
leo
Old Jul 30, 2002 | 08:45 AM
badCRX's Avatar
New User
Default Re: help: jdm b16a engine guru..identify this sensor please (dxlst)
That green one is your VTEC pressure switch. The little solenoid on top of it with the single wire is your VTEC solenoid, just an FYI.
You will need the rotor regardless if its an internal coil or external coil setup you use.
Old Aug 8, 2002 | 06:29 PM
dxlst's Avatar
Default Re: help: jdm b16a engine guru..identify this sensor please (badCRX)
cool.. anyone knows the part number? are they the same as the usdm sensor? all b series? info please
Old Aug 8, 2002 | 07:15 PM
tinkerbell's Avatar
i dont see any reason why they would be different.
part name = "VTEC Oil Pressure Sensor"
t..
Old Aug 8, 2002 | 07:16 PM
tinkerbell's Avatar
Default Re: help: jdm b16a engine guru..identify this sensor please (tinkerbell)
PS
here is hte MSD link http://www.msdignition.com/1mdcspw.htm
HTH,
t..
Old Aug 8, 2002 | 07:35 PM
dxlst's Avatar
thank you tinkerbell!
Old Aug 8, 2002 | 09:15 PM
Civic DX 4dr's Avatar
the oil pressure switch on my swap was broken when i recieved it also. i just went to the junkyard and got one off a sohc vtec motor, worked fine.
jdubEP3
Jan 26, 2012 05:23 AM
LOVEthatDC2
Aug 25, 2009 09:29 AM
PinkMaggit
Mar 12, 2007 05:43 AM
voltageGSR
Dec 7, 2003 10:28 AM
