strong smell of gas
Old Nov 2, 2008 | 02:09 PM
batallic's Avatar
Default strong smell of gas
my car was idling and my mechanic sed he smelt too much gas from exhuast, i smelt it too i still get 32 mpg so watsup
93 ex, short ram, catback exhuast
Old Nov 2, 2008 | 02:22 PM
93egSLEEPER's Avatar
Default Re: strong smell of gas (batallic)
are you running your EVAP setup? also check your fuel rail and make sure all the fitting are tight
Old Nov 2, 2008 | 02:24 PM
batallic's Avatar
EVAP setup, what is that
Old Nov 2, 2008 | 02:39 PM
Default Re: (batallic)
There should be a canister on the back of your head or intake manifold which is your evap that recirculates the gas fumes through the vacuum lines and allws them to be filtered so you dont smell them in the cab. It's not really needed, i took it off my car and there is no smell. I had a similar problem but my fuel line adapter on the tranny side of the fuel rail wasnt tightened up all the way and it cause a small smell and leak. more then likely that is your problem. check all your fuel lines
team 15
Mar 29, 2011 02:36 PM
endless22
Oct 9, 2010 06:45 AM
Acidcrakker
Nov 12, 2007 06:50 PM
HamiltonRex
10
Feb 7, 2006 05:46 PM
JBBNJ609
May 14, 2004 11:53 AM
