94 ls swap need help
k my friend bought a 94 ls off of some guy, it did have a b16 in it, he swapped it out for another ls motor when the b16 caught on fire, everything works fine, it just needs headgasket and an outer cam seal
the car won't start for twenty seconds of turning over, could it be a loss of compression with the headgasket, or would it be something in the wiring
it has the original ls ecu for the b18b1 so it shouldnt be obd trouble, also, it seems to be due to lack of fuel, if you give it gas it will work fine, i was thinking fuel pump,
also it has a slowmotion motorsports fuel rail
any ideas???
any ideas???
integra1884
May 15, 2002 10:08 AM
