problem taking heatshield off of a d16z6
Old Nov 2, 2008 | 10:28 AM
luispizarro25's Avatar
Default problem taking heatshield off of a d16z6
When i try to take it off i can see that the 02 sensor is in the way, going through the heatshield. Then i try to unclip the o2 sensor so that it goes through tthe heatshield but when i unclip it, it is still connected to the engine block. The part that comes off is the other part of the clip which is clip somewhere else.
How can i take this off pls, is causing some rattling and is pissing me off?
Old Nov 3, 2008 | 09:32 PM
Default Re: problem taking heatshield off of a d16z6 (luispizarro25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12.8:1 Ls/vtec;2455851 &raquo;</TD></TR><TR><TD CLASS="quote">unclip it from the bracket that it is held on to. It should be on the underside of the O2 sensor side, and you just have to push it in and slide it away from the bracket.</TD></TR></TABLE>
K so first of all i wanna thank 12.8:1 Ls/vte. It actually had a small clip on the back of the electrical connector. All i had to do was press it and wiggle it a little bit. It came off easily. Fortunately my stock manifold is not rusted so it doesn't look like ****. Winter is almost here so i dont care anyways. Next year im expecting a swap and new headers will come as well....
Here are so pics of what the connector looks like in a d16z6. As you can see i needed to disconnected in order to take the heat shield off. Or unscrew the o2 sensor but the later one is a bitch.
Thanks guys
-The blue arrow is the cable coming from the o2 sensor.
-The red one is the cable going somewhere else, I assume is the ECU or something like that to control the level of carbon monoxide coming from the explosion in the pistons.
thisisntjared
Apr 13, 2005 01:27 PM
Frankinfreak300
Sep 26, 2003 09:46 AM
