Power door locks dont work on 1990 Honda Accord EX
The power locks on my 1990 Honda accord ex don't work. All the locks go down and lock but only when i push them down manually. When I push the power lock button down I hear a click noise on the drivers side door. It only clicks on the drivers door even if i push the passenger button. Any suggestions?
Please search for answers to your questions. I know you are new here and are glad to have you. Usually before you post a question search for the answer, then if it doesn't come up, we can answer it.
I did search and nothing came up about a clicking noise. I took the door panel off and I pushed the button and there is a gray box that was making the clicking noise. what is this and is there any chance this could be bad?
okay; I know the search on this site is nothing to write home about.
Remove your door panel, you will find a grey box held into the vapor liner with 2 phillips screws. remove it and unplug it.
Open the box from the bottom, the guts will slide out by prying back the tabs.
Look carefully [magnifyer for us old geezers] and find the cracked solder joint.
Touch it up with some fresh solder...re install.
dohctor_B
Nov 14, 2012 11:35 AM
Tris320
Dec 19, 2007 08:48 AM
