paint of car tips
Old Nov 1, 2008 | 05:51 PM
vipcivic's Avatar
Default paint of car tips
im gonna be painting my civic and its my first time. How are you suppose to mix the primer with the hardner or the paint with the hardner can someone explain? also how much should you mix?
Old Nov 1, 2008 | 06:35 PM
KRock459's Avatar
Default Re: paint of car tips (vipcivic)
Depends on the paint, the mfr. will have the ratio listed on the paint container, and you can pick up a mixing bucket with the ratio markers on the side, easy. Make sure you get the correct hardner for the paint. When you go to your local auto body supply store, ask before you buy, they generaly know thier stuff.
Kirk R
Old Nov 2, 2008 | 09:54 AM
trepteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vipcivic &raquo;</TD></TR><TR><TD CLASS="quote">im gonna be painting my civic and its my first time. How are you suppose to mix the primer with the hardner or the paint with the hardner can someone explain? also how much should you mix?</TD></TR></TABLE>
you have to read on the cans .. to see the mixing ratio
habitually , here's the ratio :
Basecoat ( paint ) : 1:1 .. equal part of paint and hardener
Primer : 4:1 .. 4 part of primer and 1 part of hardener
Clearcoat : 4:1 .. 4 part of clear and 1 part of hardener
Old Nov 15, 2008 | 05:48 PM
syzurs's Avatar
these guys forgot, then you stir it with a paint stick.
curtie94
Sep 28, 2011 11:23 PM
stroker101
Paint and Body
Sep 4, 2007 01:46 PM
EJ8 Kenobi
Paint and Body
May 15, 2007 09:15 AM
broketuner-Sol_Si
Feb 13, 2006 09:52 PM
deeweezy
Aug 17, 2003 07:19 AM
