my 93 accord wont start!!
my car wont start, one day i was driving it then i went and get gas then it wouldnt start after that. it sounds like it wants to start but wont turn over. i change the main relay thinking that might be the problem but still not starting, i change spark plugs ,wires,dis cap, check the timing belt and it looks good and the battery is good too. any help
Procure an extra set of eyes and with the distributor cap off, crank the engine.
Said extra pair of eye's should note the distributor rotor turning as the engine cranks.
If it is NOT rotating, You've a camshaft / timing belt issue.
If it is rotating, button it up and (again) with those same pair of extra eyes;
Take a spare spark plug (doesn't need to be new), disconnect a sparkplug lead and attach it to the spare plug - rest it against the value cover.
With the engine cranking, you should see an obvious blue/white spark jumping the electrodes.
If you do, it's most likely Fuel Delivery. If you don't, it' time to consider ignition (bad module, burned cap/rotor etc)
P
P
Ef4doorwagon
16
Nov 19, 2015 03:37 PM
