1998 Honda Accord front driver side outer door handle replacement.
I need to replace the door handle of the front drivers side. I ordered a replacement but would greatly appreciate a how to. THANKS!
Remove the inside door panel, peel back the vapor barrier plastic, [razor knife the caulking]
Then with the window rolled up you can get to the 2-10mm bolts that hold the latch assy in place.
On some hondas you can wiggle the latch out and unhook the linkage from outside, some you have to reach up into the door panel to do it.
Shadowsstrife
Apr 21, 2017 06:51 PM
cavr6
Audio / Security / Video
Jun 17, 2006 01:40 PM
