Type R front Sway size?
like it says. I got a type R front assembly for free and want to know if its bigger than the GSR bar i have now.
I can install either a gsr or type r front sway, which I was going to pair w/ a type r rear sway. If the GSr and type r are the same i wont bother switching mine out.
GSR is smaller in the front. As with the rear.
If you upgrade the front without upgrading the rear, you are increasing your chances of understeering (correct me if I'm wrong). Using the ITR rear bar will correct that and even out the handling.
SlammedBlueEM2
May 28, 2003 11:21 AM
