Oil leak while running
Old Oct 31, 2008 | 08:03 PM
turb0teg's Avatar
Default Oil leak while running
The engine is a mid '90s JDM GSR, unknown miles, but runs decent. I drove the car with the hood off ("I have a mullet" style) and ran the car out in the first few gears. I slowed down and noticed some oil on my windshield, pulled over, and checked out what was going on. It's from the driver's side, front of the motor. I can't tell where it's coming from as it will drip down but also get blown upwards. I've tried cleaning off the motor untill it's spotless to see where the oil is leaking from, but I still can't tell. Anyone have some ideas of what I could look for? If it matters, my upper timing cover is off, but I haven't seen any oil from that side of the motor; it's also getting oil on the bottom of the hood, while I'm not being a redneck. If anymore info is needed, just ask.
Thanks in advance!
Old Oct 31, 2008 | 11:46 PM
GSR_hatch936's Avatar
Default Re: Oil leak while running (turb0teg)
Could it be ur cam seals??? Thats the only thing i can think of getting that much speed to go on ur wind sheild and hood..?? Check that out.
Old Nov 1, 2008 | 06:43 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: Oil leak while running (GSR_hatch936)
he said driver side. .is ur vc gasket seated properly??
Old Nov 1, 2008 | 08:55 AM
Default Re: Oil leak while running (Egezzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egezzy &raquo;</TD></TR><TR><TD CLASS="quote">he said driver side. .is ur vc gasket seated properly??</TD></TR></TABLE>
Yes I know he said driver side... Do u know there are seals around cams on both sides? And with the cams slings the oil on the windsheild. Seen this before.
Old Nov 1, 2008 | 12:52 PM
Egezzy's Avatar
yea i kno but he said he had the timing cover off but i assume the cam cover of the vc is still on so i dont see how it flick outside of that. .but if uve seen it then thurr it is. .i jus see the dist side seals leak alot mo so. .
Old Nov 1, 2008 | 04:56 PM
Just depends if his vc is cut or if its still covers the how cam gears.
Old Nov 1, 2008 | 08:05 PM
turb0teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egezzy &raquo;</TD></TR><TR><TD CLASS="quote">yea i kno but he said he had the timing cover off but i assume the cam cover of the vc is still on so i dont see how it flick outside of that. .but if uve seen it then thurr it is. .i jus see the dist side seals leak alot mo so. .</TD></TR></TABLE>
I should've mentioned my valve cover is NOT cut, so it's not on the belt, or that side of the motor for that case. I had someone local look at it, said it might be from a stripped valve cover nut not tightening down all the way.
We'll see.
On a good note, ran a 13.5 friday night
Old Nov 2, 2008 | 02:00 PM
Rukusmasta2's Avatar
remove all covers, clean thoroughly, start motor, withing 10 seconds oil will be flowing around and u should be abel to find leak.
Old Nov 2, 2008 | 07:26 PM
turb0teg's Avatar
Default Re: Oil leak while running (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">remove all covers, clean thoroughly, start motor, withing 10 seconds oil will be flowing around and u should be abel to find leak.</TD></TR></TABLE>
Like I said, I'm 90% sure it only leaks when the RPMs go high
Old Nov 3, 2008 | 05:06 AM
srmofo's Avatar
what kind of pcv system are you running? if its clogged that wwould explain only doing it at high rpms....im with everyone else though clean it good and let it run until it shows itself on the ground sometimes at can take up to an hour....they do make a UV dye that can help you figure it out
Old Nov 3, 2008 | 02:46 PM
Default Re: Oil leak while running (srmofo)
where to get that dye and is it safe?
norcalB18
Nov 17, 2009 04:38 AM
1993-eg1
Jun 7, 2009 04:05 PM
SlimBB4
Sep 5, 2007 08:20 PM
integranator
Dec 4, 2002 04:52 PM
