Code22(Could my chipped p28 be the problem)?
Old Oct 31, 2008 | 07:04 PM
SiR Inspired ED7's Avatar
Default Code22(Could my chipped p28 be the problem)?
I have an 89 Civic with a B16, the car has been converted OBD1. The car throws code 22 which is: vtec oil pressure switch. It randomly comes on and when i turn the car and then back on the code goes away but comes back after a while. <U>Could my chipped p28 ecu be the problem? </U> I havent had the time to check the wiring but I will soon, But first I am going to try another ecu and see what happens. Anyone have any advice?
Old Nov 1, 2008 | 12:47 PM
mabbiker's Avatar
Default Re: Code22(Could my chipped p28 be the problem)? (SiR Inspired ED7)
code 22 is v-tech pressure silanoid
Old Nov 1, 2008 | 01:32 PM
C_R_X_V_T_E_C's Avatar
Default Re: Code22(Could my chipped p28 be the problem)? (mabbiker)
try a stock, un-molested ecu and see if you get the same code.
if not its the ecu
if you still have code, replace vtec pressure solenoid
Old Nov 1, 2008 | 07:37 PM
Default Re: Code22(Could my chipped p28 be the problem)? (C_R_X_V_T_E_C)
I inspected vtec pressure solenoid and the plug was bad so I just replaced it and it is fixed.
Old Nov 1, 2008 | 09:22 PM
mario_pic's Avatar
its the map ur useing also can be some of the conponents if u want i got a replacent what will work 100% tell me ur setup and ill set u one up also do a trade for ur old one ill do it for 25$ canadian
Old Nov 2, 2008 | 05:49 PM
Default Re: Code22(Could my chipped p28 be the problem)? (mario_pic)
Thanks but my chip works really good I got it from http://www.phearable.net/ecutuning.html and I am very happy
civic j
Jul 25, 2007 10:15 AM
Shift_Fast
Mar 11, 2005 06:35 PM
Forrest Gump 9
Aug 3, 2003 05:44 PM
Speedz
Jun 1, 2003 07:26 AM
jack25racing
Sep 11, 2002 08:16 AM
