Detailing Auto Detailing and Concours
Presidential Detailed: 2002 Honda S2000
Old Oct 31, 2008 | 05:42 PM
Presidential_Detail's Avatar
Detailing Mastermind
Default Presidential Detailed: 2002 Honda S2000
This car provided a very good learning experience for me, the owner said it was in rough shape, and it was. I looked it over, noticed there was lots of swirling and the finish was kind of hazy. It had been sitting under a cover for nearly a year with no use. I figured it would be the run of the mill swirl removal on soft Honda paint as usual...WRONG!! Turns out the ENTIRE front half of the car from the doors forward were repainted with superman strength clearcoat. I tried everything I have, even one of the strongest compounds on the market wasnt touching these defects! I couldnt believe it. I was ready to give up and came to the conclusion the swirls were UNDER the new clear/paint. Well I was wrong again..I talked to a couple reps from Meguairs about this problem and they recommended me a new tecnique to try out..
And I went into the garage and followed the directions precisely. FIRST TRY ALL SWIRLS ARE REMOVED!!! I couldnt believe my eyes! Not to mention the fantastic gloss it leaves once finished down!
Well anyways, on to the pictures!
Exterior:
Dawn Soap Pre-Wash
Optimum Car Wash-Final Wash
DD "Uber" Red Drying Towel
DD "Uber" Wool Mitt
Dual Buckets with Grit Guards
3m "green" Masking Tape
Adams Professional Clay Bar
P21S TAW
Meguairs APC+
Meguairs Hyperdressing
Megs M105/Megs Solo Burgandy Wool(new method) x2
Menzerna PO85rd/LC FLAT Black 5.5"
Menzerna Top Inspection
Tons of Uber MF Towels
Black WOW
Griots Garage Wheel Cleaner Gel
Swissvax Pneu
LSP:
Lusso Oro applied with Uber Foam Applicator
Tools:
Dual Work Lamps
Dewalt Hi Speed Rotary
World's Greatest Boar's Hair Wheel Brush
Foam Pad Cleaning Brush
DD Detail Sponge
The Wheel Well/Fender Brush
The Spoke Brush
Canon Rebel XTi
Craftsmen 295MPH Vac/Blow
E-Z Detail Wheel Brush
Swissvax Wheel Brush
BEFORE:
The headlights were in rough shape, well take care of those later.
The owner spilled about a quart of oil on accident while performing an oil change, now my duty to clean it up! haha!
Default Re: Presidential Detailed: 2002 Honda S2000 (Presidential_Detail)
IN THE HALOGENS..
50/50 after SIP/orange SIP/yellow wool, M105, yellow wool M105/burgandy wool with 2 passes! It just wasnt removing the big ones..
Before..
After..M105/Burgandy x2
NOW after my newfound advice..
BEFORE:
AFTER 1 PASS:
BEFORE:
AFTER 1 PASS:
I ended up doing the whole car with this method twice on each panel to ensure every scratch was removed..
Pulled it out in the sun..
Old Oct 31, 2008 | 05:43 PM
Headlight Before:
50/50 with M105 on a "3 finger" green pad:
This was a night and day difference, the camera didnt seem to capture it as well.
Unfortunately, it was almost 12am when I finished and I was trying to get it done so the customer could leave, so I was not able to get as many after shots as Id like. The owner was amazed how the car looked when he came over, it was literrally glowing even at night!
Here are a couple afters I managed to get, the owner said he would take some more for me when he gets a chance...
Please forgive me for the lint, its time to invest into new MF's.
Old Nov 2, 2008 | 07:49 AM
E-Rok's Avatar
EPIC TUNING
damn I def need to get some M105, ive been meaning to for a while.
any reason you used dawn to strip the paint instead of an APC bath?
foam gun works great
Old Nov 2, 2008 | 12:23 PM
Default Re: Presidential Detailed: 2002 Honda S2000 (E-Rok)
I find the APC's to leave streaks and are a bit too harsh..nothing against them, just dont use them. Sometime I use P21s TAW to pre-soak also.
Old Nov 2, 2008 | 05:43 PM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Presidential_Detail &raquo;</TD></TR><TR><TD CLASS="quote">I find the APC's to leave streaks and are a bit too harsh..nothing against them, just dont use them. Sometime I use P21s TAW to pre-soak also.</TD></TR></TABLE>
well if I need to strip it before polsihing, Ill usually mix a small amount in with my car wash soap
Old Nov 3, 2008 | 04:23 AM
tai....'s Avatar
nice it came up really ggood
Old Nov 3, 2008 | 05:40 AM
Default Re: (tai....)
Thanks!
Old Nov 13, 2008 | 07:40 PM
ahmongboi's Avatar
Default Re: (Presidential_Detail)
i was wondering wats your new advice that you did to remove those big marks to come out so clean. And do you have to use any kind of wax or sealant after those finishes.
thanks
Old Nov 14, 2008 | 06:10 AM
Default Re: (ahmongboi)
thanks
Here ya go! I use Lusso Oro Carnuaba Wax to top off all my cars. No Sealant on this one.
Originally Posted by iamwaxman
Since you've already got the M105 and the wool pad (plus plenty of others)...
Go ahead and try this:
1. Prime the pad THOROUGHLY.
Rub it in with your hand. It'll take a bit more than you're used to applying.
2. Apply a bead of M105 to the surface, pull it in, and polish at low speed (1000 rpm).
Try 2-3 passes, or until the M105 is just starting to dry.
3. Using a fine mist, spray the surface with water.
Do not add additional product- Just re-polish with what's already in the pad.
I think you'll see a 50% improvement in the cut, but you'll probably see an increase in swirling (it can be easily removed).
After trying this method (count it as one cycle), spur the wool pad (blow it clean with compressed air if you have it).
I won't PROMISE a better result, but I am pretty sure you're going to GET a better result.
Old Nov 14, 2008 | 09:52 AM
acydphryck's Avatar
most interesting method right there...subscribed
Old Nov 14, 2008 | 04:37 PM
Default Re: (acydphryck)
Old Nov 15, 2008 | 11:11 PM
327da9's Avatar
I just got a PC and I was using XMT #1 polish on a white LC pad with my NFR s2k. How red do your foam pads get when you are detailing?
Both my orange and white pads were pretty red
Old Nov 22, 2008 | 04:29 AM
DOHCDX94's Avatar
what a difference a lil elbow grease does...clean car.
Old Nov 27, 2008 | 08:09 PM
1.5Slowmatic's Avatar
wow thats ridiculous man. I cheaped out and just got some turtle wax rubbing compound using a DA buffer with microfiber and than scratch-x. I was pleased to say the least but it was nothing like you get
Old Nov 27, 2008 | 09:23 PM
JHP's Avatar
JHP
As always, a beautiful job. Love to see your posts, got anything good coming up?
Old Nov 28, 2008 | 04:22 PM
Well, this car had been repainted so it wasnt the factory paint, it had a clear over it. However, there rear portion of the car was factory paint and it did turn my pads a little red, but its completely normal on this color with Hondas so you shouldnt worry too much. good luck!
Old Nov 28, 2008 | 04:23 PM
Sure do! Keep seated. :D
96teggynonVtec
Oct 23, 2011 02:16 PM
96teggynonVtec
Oct 17, 2011 06:07 AM
robunicu
May 25, 2011 10:27 AM
DamienB45
Detailing
Jun 29, 2010 12:49 AM
