clutch and clutch adjustment
Old Oct 31, 2008 | 12:17 PM
bkatz555's Avatar
Default clutch and clutch adjustment
Recently replaced a clutch on a stock 1998 Accord EX. 150K mi. ...Two issues remain ...
1.) The clutch now grabs just above the floor ...way too low. The play seems ok ...does not seem like i have any room to take any play out with adjusting the pedal. I've read on a forum somewhere that the clutch system compensates for wear. ... is there a way to re-set that auto adjustment ? How does that auto adjust work?
Any other ideas??
I bought the clutch at the local autoparts store ...should have been an OEM equivalent.
2.) I now have a squeak / rattle / whistle type sound as the clutch grabs. .... I did the stupid and unthinkable ...I did not have the flywheel turned ...by the time the flywheel was out, all the places were closed on that Sat and I needed the car monday ....Flywheel looked fine ...no grooves, no visible problems ....I sanded it well and kept it clean and re-installed ...I needed the car. ....
10K mi later, it is still doing it, but same or less than when it was first installed.
Anybody else run into a high pitched squeal / vibration from a new clutch? Sounds like the disk is probelmatic?
Thanks.
lude98SH
Feb 21, 2006 07:28 AM
Confuc1ous
Mar 31, 2005 04:41 PM
t04ecvc
Apr 20, 2004 03:38 PM
