205/60/15 Will they fit the stock usdm rim?
Just as the title states, Might be able to pick up a set of some dirt cheap tires and throw them on some stockers. Car is not lowered.
And if they do fit, any pictures of this done?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">they do, but are gonna look and feel like ****.</TD></TR></TABLE>
X2
Balloon look comes to mind
X2
yeah I was afraid of that but I can get a set of 4 blizzaks for 45 locally. I might be having to drive the R this winter, so I wanted to be prepared. I was hoping I wouldn't have to, but it looks more like it as winter approaches.
I'v driven on 205/55/15 and they were huge, I rubb while steering etc. Do they have any options with a narrower tread?
I Googled "205/60/15 Integra" and came up with this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1ej8 »</TD></TR><TR><TD CLASS="quote">Pictures:
Wheel and Suspension Modifications: Ls Webs, Falken Ziex 912 205-60-15</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001TypeR »</TD></TR><TR><TD CLASS="quote">Ive got 205/50/15 and no problems. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi »</TD></TR><TR><TD CLASS="quote">205/60/15
Thanks</TD></TR></TABLE>
Most of us have or do use 205/50-15 w/o problems...
yeah I was afraid of that but I can get a set of 4 blizzaks for 45 locally. I might be having to drive the R this winter, so I wanted to be prepared. I was hoping I wouldn't have to, but it looks more like it as winter approaches. </TD></TR></TABLE>
As long as you are not lowered and just intend to use them as winter tires then I dont see a problem other than not looking aesthetically pleasing.
205/60-15 can be mounted on 15x6 rims without problems. That size is 5.3 percent (an inch and a quarter) larger in diameter than the stock tire size. I'm guessing they will rub, and if they do, it's a problem (and can be serious if it's more than just touching the wheel well liner on full lock of the steering wheel). Other side effects are that the speedometer and odometer will both read lower than actual by that percentage, the ride height will be greater by about 0.6 inch, and the car will accelerate slower (like using taller gears) - none of which may be all that big a deal if it's just for winter. You can try it, but if they rub too bad, don't use them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">That is a tall tire.
Dune buggy R FTW!
That's right! That extra 0.6 inch of ride height will make your Integra Type R as tall as - gasp! - other Integras!!!
Dune buggy R FTW!
</TD></TR></TABLE>That's right! That extra 0.6 inch of ride height will make your Integra Type R as tall as - gasp! - other Integras!!!
