00 teg GSR Steering wheel issues
Ever since it got cold, when I turn my steering wheel left and right it sweaks. Not too loud when driving but when parked, moving the wheel you can hear the sweaking. What is the problem here. Anything major? Also, are you guys having issues with the brake light staying on, on a cold day. I had a PY ITR before until it got stolen and also had that issue. Must be a TEG thing.
i have the similar problem with my PS , it sounds like theres low fluid and it wines when you turn the wheel when its cold, and fluid is full... and only has happened when its cold out side here , anything major
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caiboR »</TD></TR><TR><TD CLASS="quote"> Also, are you guys having issues with the brake light staying on, on a cold day. </TD></TR></TABLE>
The light will only come on when the e-brake is pulled or if the fluid is low, you might want to check your master cylinder and make sure the bob in there isn't being hung up on anything like build-up on the walls of the reservoir.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ac_attak »</TD></TR><TR><TD CLASS="quote">Is it your actual steering wheel that squeaks, or something connected with the steering in the front end?</TD></TR></TABLE>
Sounds like it's coming from the steering in the front end. Maybe something should be lubed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 »</TD></TR><TR><TD CLASS="quote">
The light will only come on when the e-brake is pulled or if the fluid is low, you might want to check your master cylinder and make sure the bob in there isn't being hung up on anything like build-up on the walls of the reservoir.</TD></TR></TABLE>
Your talking about the clutch fluid right?
MUGEN_EG95
Honda Civic (2006 - 2015)
Jan 15, 2009 09:01 AM
aberle99
13
Jan 30, 2008 12:37 PM
NGUSPEED
Dec 27, 2007 08:03 AM
azncollegeguy
Feb 18, 2005 01:14 PM
