ITR Cluster install
No, just unscrew the bezel first, then the four screws holding the cluster in there. Unclip the plugs in the back and reverse with ITR cluster.
i rand into some problems when i installed jdm itr cluster.. had to remove all the gauges off the itr cluster and re-install them on my oem cluster apparently the circuitry is different.. lol
it's only if you switch through 94-97 to 98+ that you have to swap the circuit board (green film). If you go from 96 itr to a 96 LS for instance it's plug and play, same with 98 itr cluster to 98 LS/RS/GS, it's plug and play. But 96 ITR cluster to 98 and vice versa is not plug and play but would need the circuit board swapped over.
