What should the gauge needle say??? 93 accord
Old Jul 30, 2002 | 04:44 AM
Charlie Moua's Avatar
Default What should the gauge needle say??? 93 accord
what should my compression be? I have a 93 ex.
Old Jul 30, 2002 | 05:04 AM
Ahab's Avatar
Default Re: What should the gauge needle say??? 93 accord (Charlie)
Don't really know about the '93, but my '94 was supposed to be somewhere in between 135lbs to 175lbs. Mine was really low with just 90lbs.
Old Jul 30, 2002 | 05:08 AM
greensleeper's Avatar
Default Re: What should the gauge needle say??? 93 accord (Ahab)
What the hell are you talking about?
Old Jul 30, 2002 | 07:26 AM
Default Re: What should the gauge needle say??? 93 accord (greensleeper)
talking anout the compression testing.
Old Jul 30, 2002 | 08:00 AM
When I think of compression I think of ratios and such. What exactly do the lb measurements indicate?
Old Jul 30, 2002 | 09:10 AM
Ahab's Avatar
It's just the pressure that builds up in the cylinders. Simple check tells whether you might be getting blow-by around the rings. Or in my case if the engine is wore out.
Old Jul 30, 2002 | 01:01 PM
anyone else?
Old Jul 30, 2002 | 03:44 PM
Nick H's Avatar
New User
edit: 4th gen is 165 lbs
[Modified by nickh2k1, 7:49 PM 7/30/2002]
jojo69
May 11, 2006 05:36 PM
ghostofnyc
Oct 11, 2005 04:07 AM
spooncivic1
12
Nov 24, 2004 07:35 AM
spladam02
14
Dec 15, 2002 02:55 AM
