check engine light help
Old Oct 31, 2008 | 01:43 AM
down4honda's Avatar
Default ELD code
I have a 90 acura integra (DB1) and its throwing a ELD code. I recently replaced the terminals and a new alternator and its still throwing the code. any help?
Old Oct 31, 2008 | 06:47 AM
92DAIntegraXSI's Avatar
Default Re: ELD code (down4honda)
ELD is in the fuse box underhood if i remember correctly. you need to relace it. dont quote me on which fuse box tho.
Old Oct 31, 2008 | 01:35 PM
down4honda's Avatar
Default Re: ELD code (92DAIntegraXSI)
so i need to replace one of the fuse boxes?
Old Oct 31, 2008 | 02:43 PM
kronikSLOW's Avatar
no you dont need to replace the fuse box. you may need to replace one of the fuses or fuse connections. the box is just that a box that hold electrical connections.
Old Nov 1, 2008 | 11:27 AM
Default Re: ELD code (kronikSLOW)
dude the ELD? the eld is located in the underhood fusebox. You have to replace the fusebox/eld as one unit since its built into the bottom of it. OP said he replaced the alternater and battery terminals. That shows he has a charging system problem. If hes throwing a ELD code 20 if i remeber he may either have a blown fuse or THE ELD is bad. If you knew anything about this problem integras have it with old age!.
Old Nov 2, 2008 | 03:24 PM
down4honda's Avatar
thanks for the info. im going to be looking into all that.
crxjarred
Jul 26, 2009 12:06 PM
jason.az1
Dec 13, 2008 10:01 AM
Bo0sted4Do0r
Apr 27, 2006 09:38 AM
Oren
Feb 22, 2005 12:26 PM
Dan GSR
Dec 22, 2004 10:37 PM
