HELP!!! Accord Euro R swap in 4th gen Prelude
Old Oct 30, 2008 | 08:16 PM
redvtec's Avatar
Default HELP!!! Accord Euro R swap in 4th gen Prelude
I have an accord euro r h22a motor sitting on a lift and i can not find a decent parts list for what needs to be done to switch it from and OBD2 to an OBD1 so that it will work with the ecu out of a 95 prelude vtec. Can any one help me with this list of parts???
Old Oct 30, 2008 | 08:23 PM
vinuneuro's Avatar
Default Re: HELP!!! Accord Euro R swap in 4th gen Prelude (redvtec)
Your 95 usdm won't operate the engine properly since the EuroR has 1pt higher compression, and different cam timing. Use the ecu that you get with the swap.
Old Oct 30, 2008 | 08:34 PM
A Blue Lude's Avatar
Default Re: HELP!!! Accord Euro R swap in 4th gen Prelude (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Your 95 usdm won't operate the engine properly since the EuroR has 1pt higher compression, and different cam timing. Use the ecu that you get with the swap.</TD></TR></TABLE>
The Euro-R ECU would be hard to make work.
Your main issue will be getting the IM stuff hooked up right: throttle cable, fuel rail, and IACV. Probably a good idea to keep your distributor and put it on the new engine.
Old Oct 30, 2008 | 08:49 PM
redvtec's Avatar
Default Re: HELP!!! Accord Euro R swap in 4th gen Prelude (A Blue Lude)
It didnt come with the Euro R ecu.
A Blue Lude- are you saying that it would be easier to use my stock ecu which will have a hondata s300 on it?
Old Oct 30, 2008 | 09:02 PM
no1knows908's Avatar
Can't use any Prelude ECU with Hondata S300, must use a P28 or similar Civic/Integra VTEC ECU.
Old Oct 30, 2008 | 09:32 PM
ShoofIsLudin's Avatar
since ur putting this motor into a 95, you'll probably have to change the distributor and oil pump, and ur ECU. There are lots of ppl on here that know exactly what's needed for the obd2-obd1 change over.
The best thing you can probably do is get a p28/p72 and get it socketed and tuned.
Old Oct 30, 2008 | 09:33 PM
redvtec's Avatar
Default Re: HELP!!! Accord Euro R swap in 4th gen Prelude (no1knows908)
so i need to find a civic or integra vtec ecu to use a s300??
Old Oct 30, 2008 | 09:35 PM
redvtec's Avatar
Default Re: HELP!!! Accord Euro R swap in 4th gen Prelude (ShoofIsLudin)
thank you so much, yeah i figured id need those two but im worried about the fine detail stuff going from obd2 to obd1
Old Oct 31, 2008 | 06:05 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no1knows908 &raquo;</TD></TR><TR><TD CLASS="quote">Can't use any Prelude ECU with Hondata S300, must use a P28 or similar Civic/Integra VTEC ECU.</TD></TR></TABLE>
Kind of a BROAD statement......You can use a USDM OBD2 ECU with it(needs at least a vafc to tune, to run right)......but that obviously isn't an option for his OBD1 setup.
Old Oct 31, 2008 | 11:12 AM
vinuneuro's Avatar
If you don't have the correct ecu to run this engine, you must get it tuned.
Old Oct 31, 2008 | 12:36 PM
NirVTEC's Avatar
Hmmm....where is Washington , IL? If its anywhere near Chicagloand, One6 Motorsports can help. Their shop DRAG car has a EuroR running an H22.
Old Nov 2, 2008 | 10:47 AM
redvtec's Avatar
Default Re: (NirVTEC)
Yeah it is about 2 and a half hours away from chicagoland. Would they be able to tune a p28 w/s300 ecu and tune the motor if i already had it installed?
Old Feb 1, 2009 | 03:48 PM
redvtec's Avatar
Well the motor is finally in. All that is left is exhaust and tune. Most of the things hooked up very easily the only thing that really posed a problem was going from low Ohm injectors to high Ohm injectors on the new motor. Id like to thank you all for your input on all of this swap it really helped out a lot. I am so happy that I took my time, did a lot of research, and had helpful people to make this swap pretty straight forward.
Old Feb 1, 2009 | 10:53 PM
mattsnooz's Avatar
wheres the pics ya big jerk!! lol
Old Feb 2, 2009 | 03:31 PM
redvtec's Avatar
Sorry guys ill get the pictures up really soon.
Old Feb 2, 2009 | 04:31 PM
92civlude's Avatar
There are a few subtle differences between the Euro-R and H22a1
You must use the Prelude harness because the Euro-R is void of the VTEC oil pressure switch, there is a plug where the oil pressure switch normally bolts up.
There is also NO front crankshaft speed sensor on the Euro-r, so go OBD1
The front motor mount bracket (by the timing cover) has a different bolt pattern, youll have to use the Prelude bracket.
The alternator connector is different than the Prelude connector, youll have to use the Prelude alternator.
The starter cable on the Euro-R is on the other side of the starter, youll either have to get a longer positive battery cable or use the Prelude cable.
If you use the Euro-R intake manifold and injectors, Youll have to by-pass the Prelude injector resistor. This is much easier than getting OBD1 injectors to fit on the Euro-R manifold.
Youll also need an IAC to EACV adapter plate. Blacktrax has them.
I ran a JDM P13 ECU for a few weeks, Ran great.
But now im running a Phearable ECU.
Other than that, the swap was straightforward.
Old Feb 2, 2009 | 04:34 PM
92civlude's Avatar
Sorry bro! I didnt see your last post! Lets see some pics.
Old Feb 2, 2009 | 04:42 PM
redvtec's Avatar
Thanks i believe i took care of all that stuff.
Ill get pictures up just as soon as i can.
Old Mar 15, 2009 | 12:52 AM
redvtec's Avatar
Finally got the pics.
Old Mar 15, 2009 | 03:06 AM
Apex1972's Avatar
very nice!!!
Old Mar 15, 2009 | 04:34 AM
Pullig's Avatar
what muffler is that i like the way it looks... how does it sound
Old Mar 15, 2009 | 05:43 AM
mattsnooz's Avatar
Yeah, wheres the sound clip ya big jerk LOL jk
Old Mar 15, 2009 | 11:13 AM
PremiumPrelude's Avatar
I have this in my black prelude, seems to still be running a little crappy and im still trying to figure out some of the buggs
Old Mar 15, 2009 | 11:18 AM
redvtec's Avatar
Thanks guys I am really happy with it.
Its a magnaflow universal muffler. I had a custom exhaust put on it. I think it sounds absolutely sick. People tell me it doesnt even sound like a honda, it has a great crawl to it now. If you want ill give you a link to it and how to get an even better price on it.
Old Mar 15, 2009 | 11:41 AM
redvtec's Avatar
Do you have the full motor and trans combo? What exactly do you mean by running crappy. Did you have it tuned? Where did you have it installed at?
