Installed dsm injectors.. stock LS
Old Oct 30, 2008 | 07:57 PM
2ndchirp's Avatar
Default Installed dsm injectors.. stock LS
Ok so today i got my hands on some 450cc injectors from a turbo 2.0 eclipse engine... well the car turned on fine and idled fine .. i used the 10ohm 10 watt resitors ...but it kept braking up at high RPM'S.. my question is if i get a fuel pressure regulator and lower the pressure a lil bit will that fix the problem?
Old Oct 30, 2008 | 08:46 PM
Jimmy's Avatar
Global Moderator
Default Re: Installed dsm injectors.. stock LS (2ndchirp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">Ok so today i got my hands on some 450cc injectors from a turbo 2.0 eclipse engine... well the car turned on fine and idled fine .. i used the 10ohm 10 watt resitors ...but it kept braking up at high RPM'S.. my question is if i get a fuel pressure regulator and lower the pressure a lil bit will that fix the problem?</TD></TR></TABLE>
I doubt that will fix your issue..
You need some kind of engine management to turn the fuel down in the 450cc injectors.. such as chipped ecu (crome, etc) old school vafc hack, etc
Old Oct 30, 2008 | 08:55 PM
Jimmy's Avatar
Global Moderator
Also i just noticed topic title.. ''stock LS''
If it's not boosted.. why are you running/wanting to run dsm 450cc injectors?
Old Oct 31, 2008 | 09:25 AM
2ndchirp's Avatar
Default Re: (Jimmy)
Well now im spittin fireballs lol.. But yea i kno only cars that are boosted use those injectors but if i can turn the fuel down a lil bit i kno i can gain more power out of my ls.. i have a sleeved block with cp pistons 12.6:1 compression that i willl be putting in my car in a few weeks but i was just trying out those injectors and i am going to get it tuned because tuned LS is a beast ...talkin from experience and no its not completly stock.. i just meant non turbo
Old Oct 31, 2008 | 09:43 AM
mmuller's Avatar
Mad Scientist
Default Re: (2ndchirp)
lowering fuel pressure wont cut it for you.
Old Oct 31, 2008 | 09:47 AM
Schister66's Avatar
Man U FTW
You need a good EMS to run those. You can't honestly expect to just throw a set of 440s in and have it run...
Secondly, there is NO point for you to run those injectors on your stock LS. That's just obsurd. But i guess you'll do what you want.
Old Oct 31, 2008 | 10:32 AM
akandok's Avatar
Default Re: (Schister66)
440s in an LS?
Old Oct 31, 2008 | 10:33 AM
akandok's Avatar
check my setup.. Im still running stock injectors.. Im going to pass smog and throw in my hondata
Old Oct 31, 2008 | 10:51 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: (akandok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok &raquo;</TD></TR><TR><TD CLASS="quote">
440s in an LS?
x2.
Old Oct 31, 2008 | 06:50 PM
2ndchirp's Avatar
Default Re: (Byaaah!)
i decided to just sell the injectors cuz i need the money to finish my all motor setup
Old Oct 31, 2008 | 06:54 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">i decided to just sell the injectors cuz i need the money to finish my all motor setup</TD></TR></TABLE>
good decision
Old Oct 31, 2008 | 06:58 PM
2ndchirp's Avatar
Default Re: (Jimmy)
it was sure fun shooting fire ***** out my 4inch tip lol
Old Oct 31, 2008 | 07:16 PM
2ndchirp's Avatar
How much would they be worth?
Old Oct 31, 2008 | 07:18 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">How much would they be worth?</TD></TR></TABLE>
ahhh depends.. $60-$100 bucks
Old Oct 31, 2008 | 07:34 PM
2ndchirp's Avatar
Default Re: (Jimmy)
ok thanks
Old Nov 4, 2008 | 03:24 AM
cmillette's Avatar
your drowin it out. go back to original injectors. wait till you need that large if size
Old Nov 4, 2008 | 06:48 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">it was sure fun shooting fire ***** out my 4inch tip lol</TD></TR></TABLE>
and burning out your valves at the same time
Old Nov 4, 2008 | 07:40 AM
Byaaah!'s Avatar
Default Re: (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
good decision </TD></TR></TABLE>
x2.
Old Nov 4, 2008 | 09:57 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">Well now im spittin fireballs lol.. But yea i kno only cars that are boosted use those injectors but if i can turn the fuel down a lil bit i kno i can gain more power out of my ls.. i have a sleeved block with cp pistons 12.6:1 compression that i willl be putting in my car in a few weeks but i was just trying out those injectors and i am going to get it tuned because tuned LS is a beast ...talkin from experience and no its not completly stock.. i just meant non turbo</TD></TR></TABLE>
dude who the hell lied to you and told you larger injectors on a stock engine will help power? if anything running on the factory duty cycle on the stock injectors will cause damage internally.
wantboost
Feb 10, 2013 08:33 PM
boonacka
Aug 16, 2004 09:30 AM
liquidxEG
Jul 18, 2004 07:20 AM
dominate9
Oct 14, 2003 09:48 AM
