help guys loud clicking noise on drivers rear tire
Old Oct 30, 2008 | 07:48 PM
JUNKIE DUCKY's Avatar
Default help guys loud clicking noise on drivers rear tire
92 honda civic si
everytime i make a left or hit a heavy bump my car makes this clicking noise in the back its really loud i change suspension in the back and still the same i check all nuts and there tight .....they told me it could be the wheel bearing but it dont really make noise when im going i cant figure it out help
Old Oct 30, 2008 | 07:58 PM
mikehawk's Avatar
Default Re: help guys loud clicking noise on drivers rear tire (JUNKIE DUCKY)
might be a silly question .. but are your lug nuts tight?
Old Oct 30, 2008 | 08:25 PM
Default Re: help guys loud clicking noise on drivers rear tire (mikehawk)
is not that much of a silly question because the first time it did i thought that was it but it wasnt ........the bushings look good too i dunno is so confusin
Old Oct 31, 2008 | 07:52 AM
bump
Old Oct 31, 2008 | 08:28 AM
davefromPA's Avatar
something rattleing around?? i had a golf ball in the frame of my taurus that rattled around a while back. are your rear wheel studs in properly?
Old Oct 31, 2008 | 09:17 AM
Default Re: help guys loud clicking noise on drivers rear tire (davefromPA)
yeah no is like a loud clicking noise you can hear like from half block away and its like a pattern like the click are separated by the equal of amount of time does that make sense
Old Oct 31, 2008 | 09:44 AM
davefromPA's Avatar
discs or drums in the rear?
Old Oct 31, 2008 | 09:48 AM
halocore's Avatar
did you check your axles? that could be the cause of it clicking everything you turn.
Old Oct 31, 2008 | 10:01 AM
Default Re: help guys loud clicking noise on drivers rear tire (halocore)
its and si so disc and is in the back axles are fine
Old Oct 31, 2008 | 10:57 AM
davefromPA's Avatar
did you take your tire off and look at the setup? im guessing you did to check the bushings but have to ask
MonkeyMagic's Avatar
check the sway bar end links
Old Oct 31, 2008 | 11:01 AM
Default Re: help guys loud clicking noise on drivers rear tire (MonkeyMagic)
oh **** really?
Old Oct 31, 2008 | 11:04 AM
i ddnt see a sway bar?
Old Oct 31, 2008 | 11:19 AM
if its a si, you should have a rear sway bar.
but a worn out sway bar link bushing would cause a distinct 'clunk' when you hit a bump.
Old Oct 31, 2008 | 11:53 AM
yup thats it im gonna check it out thanx for your help
Old Nov 2, 2008 | 01:16 AM
so no sway bar check the bearings look good i check everything
Old Nov 2, 2008 | 10:06 AM
bump
swabby
Honda Civic (2006 - 2015)
12
Aug 23, 2006 08:40 AM
TheNasty0ne
11
Nov 29, 2005 04:58 PM
SpoonFed
Feb 26, 2002 01:41 PM
