need some help with dangerous braking prob.
i have a 91 civic si and put a b16a and one day when driving, my brake pedal got stiff. now, when i push the brakes, its stiff and my idle jumps up to 2k and cant stop how i used to. any help would be highly appreciated. thanks for your time.
You need a brake booster. When the brake booster goes bad, it leaks and lets the vaccum in and makes the car rev higher, cause a brake booster works off of a vaccum from the engine. So if its leaking vaccum it wont pull the diaphram which makes the pedal very very hard to push.
Just get a new brake booster and you will be good.
Another thing when you get in the car start it up and push the brake, you should hear a hissing, leaking air sound.
G2hybrid
Aug 9, 2006 09:26 AM
CLICC916
Apr 26, 2004 08:11 AM
the testing procidure should prove most usefull!
