D16Z6 valve springs and retainers in a D15B2 head?
Old Oct 30, 2008 | 04:27 PM
HaulingAddison's Avatar
Default D16Z6 valve springs and retainers in a D15B2 head?
Just woundering if aftermarket valve springs and retainers for a D16Z6 will work on a D15B2 head. I can't find any aftermarket springs or retainers for the D15B2 anywhere. So will D16Z6 valve springs and retainers work on a D15B2?
Old Oct 30, 2008 | 05:33 PM
welfarepc's Avatar
they should work fine the valves are the same
cbr springs in a d series?
Old Oct 31, 2008 | 06:14 AM
jlicrx's Avatar
Default Re: D16Z6 valve springs and retainers in a D15B2 head? (HaulingAddison)
D15B2 valve springs:
free length - intake = 48.58mm - exhaust = 49.19mm
installed height - intake = 46.985mm - exhaust = 48.965mm
D16Z6 valve springs:
free length - intake = 57.97mm - exhaust = 58.41mm
installed height - intake = 53.165mm - exhaust = 53.165mm
the D15B2 and D16Z6 valves are not the same
Old Oct 31, 2008 | 02:12 PM
Default Re: D16Z6 valve springs and retainers in a D15B2 head? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">D15B2 valve springs:
the D15B2 and D16Z6 valves are not the same</TD></TR></TABLE>
Well that sucks. It's hard to find anything performance wise for a D15B2. I was mostly hoping that the valve springs were the same. Anyways, thanks for the info.
Old Nov 6, 2008 | 05:26 PM
welfarepc's Avatar
i just realized today i gave you bad info. sorry man. good thing someone was paying attention.
for anyone who cares d15b2/b1/b7 and d16a6 share the same springs
Old Nov 6, 2008 | 07:15 PM
Furyof4's Avatar
You can use any spring made for the d16a6 in a b15b2. They have the same valves and head casting.
Old Nov 8, 2008 | 01:09 AM
Default Re: D16Z6 valve springs and retainers in a D15B2 head? (Furyof4)
Ya, I was able to find that much out on old posts I seached. I knew the non-vtec D16A6 was the same, just wasn't sure about the D16Z6. I acually found a company that makes aftermarket valve springs rated to 9900rpms for the D15B2. The company is Bisimoto. They have a few products for Honda's vtec and non. It took awhile to find this company, but they have a bit of stuff to build a sohc non vtec.
Novatec
Sep 13, 2017 07:48 AM
88LsRex
Mar 10, 2012 11:14 PM
wfocrx
Sep 6, 2007 08:35 AM
Fallen86
Aug 16, 2006 04:23 PM
