haveing some problems with a 90 si crx
here is the problem. I live in vegas and have smog issues like you do in cali. have a 90 crx si using a d15b7 block with a d16a6 head. i put the motor together and she fired right up however she smokes under acceleration. not at idle, only when going from a dead stop. even if i baby it, it still smokes. I have taken the car to a reputable shop here in vegas (Hondoctors) and they did a pumpdown test (came out good) also did a comp test ( also good 180, 182, 181, 179) they checked my valves and adjusted them. put a runright treatment on it. and it still does it. it is running rich. (not burning oil or watter).
here is what i have done so far tell me if i missed something please.
distributar
cap
rotorbug
plug wires
spark plugs
o2 sensor
fuel filter
fuel pump
changed ecu's
changed charcole cansister
the injectors are stock as is the fule rail and psi regualtor
realy need this up and running. gettting pissed of at it, been at it since june with this. any suggestions will help. thanks.
also has cat and is original ( don't think that i would have anything to do with it put thought i would just tell ya.)
distributar
cap
rotorbug
plug wires
spark plugs
o2 sensor
fuel filter
fuel pump
changed ecu's
if the head was hot tanked or solvent cleaned and the valve seals were never replaced then that would be the issue, but you said it doesn't burn any oil..... so i don't know.
the valves are seating. when i pulled the head i used carb cleaner on the shut valves to see if leaked throug and it didn't. i know that the head and valves are good and so is the block. i'm realy lost right now with this thing.
sorry ment to say seals. they were checked when we did the leak down test. also tested them with carb cleaner and they did not leak.
ok. tryed the fuel injectors. did not help. also put a freinds head on the car and still smoked (note. the head did not smoke on freinds car.)
any more suggestions. this is killing me.
89CRXSIHutch
Jul 18, 2008 01:36 PM
bmg123
43
Jun 27, 2007 08:36 AM
