Suspension & Brakes Theory, alignment, spring rates....
sway bar making car harder to steer
Old Oct 30, 2008 | 01:43 PM
jplowman2005's Avatar
Default sway bar making car harder to steer
i just installed a gsr front sway bar on the front of my 99 hatch without power steering and it fills like i have to use more power to turn my steering wheel when taking anything more than a small turn, am i imagining this or is this a side affect of installing a sway bar???
Old Oct 30, 2008 | 06:08 PM
alphalanos's Avatar
Default Re: sway bar making car harder to steer (jplowman2005)
You increased the understeer installing a larger front bar. Youll have to counteract it by installing a rear bar or a larger rear bar if you already have one. You can also increase your rear spring rates and increase negative camber in front to make it better.
Old Oct 30, 2008 | 07:37 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Correct me if I'm wrong, but the swaybar shouldn't make any difference in steering effort if the front end of the car isn't actually sliding, right? Yeah a bigger front bar can make the front slide when taking a hard corner, but what about normal driving? I don't see how a larger front sway bar would affect steering in those cases.
Modified by PatrickGSR94 at 5:37 AM 10/31/2008
Old Oct 30, 2008 | 09:04 PM
mormonboy's Avatar
Default Re: (PatrickGSR94)
hmm.. prolly installed something wrong? maybe there are some binding issues wit the bushings? or something? just a guess.
Old Oct 31, 2008 | 04:12 AM
string's Avatar
If you're increasing the work the front tyres are doing, they will be trying harder to align themselves against where you're pointing. i.e. more steering force due to higher tyre aligning torque.
Old Oct 31, 2008 | 09:21 AM
Community Builder
Default Re: (string)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by string &raquo;</TD></TR><TR><TD CLASS="quote">If you're increasing the work the front tyres are doing, they will be trying harder to align themselves against where you're pointing. i.e. more steering force due to higher tyre aligning torque.</TD></TR></TABLE>
I could see this happening if our cars had high caster angles like many German cars and other newer cars with Mac struts up front. But our steering knuckles are so close to vertical that I don't see how adding or stiffening the front sway bar would have any effect on steering at normal driving speeds.
Old Oct 31, 2008 | 09:46 AM
jwlee7ucla's Avatar
he did say he had no powersteering, and "anything but a small turn", thats probably why the effect is more pronounced.
get a rear sway man, stiffen up that rear
Old Oct 31, 2008 | 05:09 PM
thanks for the input, i have a gsr reay sway bar as well but i can figure how to mount it...the only holes i have on my rear lca's seem to be a few inches wider than the swaybar linkage piece, and the 2 mounts that go on the frame, well i dont have anywhere to mount them, and the holes i do see are to far apart..any help here
neozero999
Apr 22, 2008 04:39 PM
TegoDC5
Suspension & Brakes
14
Sep 13, 2005 08:45 AM
EGTeK
Dec 11, 2002 03:29 AM
sfr4dr
20
Sep 28, 2002 12:09 PM
