1997 INTEGRA PART OUT, 97 LS INTEGRA MOTOR SWAP,D15b SWAP, CIVIC PARTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 30, 2008 | 12:19 PM
Chizle707's Avatar
Default 1997 INTEGRA PART OUT, 97 LS INTEGRA MOTOR SWAP,D15b SWAP, CIVIC PARTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hi i have some parts for integras and civics,im also posted on Craigslist... I will take all reasonable offers... I also have the whole chasis of a 1997 integra that I had bought from a lady, i have had some friends take some parts off, but mostly everything is still there, go ahead and call me(NO PMS) if you are interested in anything...My number is 707-372-3102...Located in Vacaville California.
-Hx rims(all 4) with dunlop sport a4's, 185/65/14's. About 80% tread left. Rims are in excellent condition, painted gold with center caps- Sold
-Integra steelies,i have 2 rims by themselves,(no tires)i got them sandblasted to bare metal so that the next person that buys them can paint them- $40
1997 Ls Swap, Everything is there except axels. The motor is a B18B1 which came out of a completely stock Integra. Milage on the motor is 84,xxx miles. The motor has no issues and has been well maintained and taken care of. Car has clean vins and is a legit motor. The following items had been changed on the car at approximately 72,xxx miles.
-Timing belt,water pump, valve adjustment done to factory specs,new valve cover gasket,and gromet set, transmission flush, and distributor o-ring was just recently changed out,along with spark plugs,wires,cap and rotor.
What will be included in the swap-
-Complete long block and transmission with ac bracket,ac compressor,power steering pump and bracket,alternator,intake manifold,distributor,sensors,o2 sensor, starter, wiring harness,etc. Basically how it came out of the car.
-All motor mounts and brackets out of the integra
-Ls integra shiftlinkage and shifter
-Stock ecu out of the integra
-Wiring harness
-transmission
All you are missing out of the swap are axels.
Asking price for the swap is 1600obo, considering all the work and parts that have been put into the motor. No trades, just cash.
-d15b motor swap,out of a 92 honda civic cx, motor has approximately 135,536 miles, new water pump,timing belt, valves adjusted,new valve cover/gromet kit. Motor ran great,never had any problems with it,passed smog and got 34-38mpg. -Reason the motor was pulled out was because i put a integra motor in my hatchback. Comes with ,complete engine and tranny,shiftlinkage,axels,wiring harness.-$600obo
-Also Have 98 Gsr tranny, it has 81,xxx miles, comes with speed sensor,fork,throwout bearing, and can even include stock flywheel that has been resurfaced at the machine shop.-$600obo
-Also have stock gsr shiftlinkage, comes with stock shifter,$90obo
-Also have an integra full size koyo radiator,no leaks or damage,used, $300obo
-Used fidanza flywheel, 7.5lbs,used for about 2500 miles,for a b-series hydro
- Make offer
-Acl bearings for b18c1,and also have acl bearings for a b18b1- $75obo
Also have some integra mounts,powersteering pumps,t brackets, etc,make offer
You can contact me at 707-372-3102
Keywords: honda,civic,lx,dx,cx,vx,si,crx,ef,dc,eg,ek,type r,da,ls,hx,gsr,koyo,exedy,flywheel,integra,hatchba ck,h22,d15b,d16y7
b18b1,b18c1,b18c5,swap,acl bearings,
Old Nov 3, 2008 | 03:15 PM
esean93's Avatar
Default Re: 1997 INTEGRA PART OUT, 97 LS INTEGRA MOTOR SWAP,D15b SWAP, CIVIC PARTS!!!!!!!!!!!!!!!!!!!!!!!!!!
i need the integra throttle cable.how much would u sell it for?
DaLove91
Dec 28, 2024 08:41 PM
slvrslepr
Mid-Atlantic (Sales)
Nov 29, 2012 06:57 PM
IHeartVTEC
Apr 1, 2005 02:38 PM
wsiracerz
May 22, 2004 01:56 PM
