98 6cyl magnaflow cat-back --> 00 4cyl ??
will it fit?
i've been looking around and it looks like the routing is a little different but i figured one of you guys would know i'm away at school and can't look under my car
I can be made to fit, but it does not bolt on.
If you get a good deal and a friend who can weld, then grab it. Otherwise you'll be spending a bunch to have it installed.
i have access to a welder and someone who knows to weld better than me, the guy who's selling it said he cut about a foot and a half off the end by where it bolts to the cat. i need a new cat anyway, and universals are cheaper than the bolt-ons. do you know if the hangers and rest of it will match up if i weld on new flanges and the tubing to make it reach? its from coupe --> coupe thanks
does anyone think it's a good idea//bad idea and why or why not?
working on this car is so much different from my truck
You'll have to add the hangers on the drivers side in the rear for the second muffler. otherwise I think all the hangers are the same.
Since you've got a friend who welds then it won't be a big deal.
I don't really see any disadvantage to it. You already know it's going to require some fab work, so as long as you're ok with that, go for it.
helbreath
Dec 20, 2016 10:15 AM
SpOoNsKi
Aug 14, 2006 06:46 PM
