CRX si B16A A/C EXTRIMLY CLEAN T/W
Old Oct 30, 2008 | 10:50 AM
thehondaconnection's Avatar
Default CRX si B16A A/C EXTREMLY CLEAN T/W
IM POSTING THIS CAR FOR A FRIEND ITS VERY CLEAN AND I CAN VOUCH FOR IT
NO TRADES OF ANY KIND
DRENICA CUSTOMS AUTO.COM
42160 US HWY 19North SUITE 26
TARPON SPRINGS
FLORIDA 34689
727-505-5521
http://WWW.DRENICACUSTOMSAUTO.COM
ENGINE MODS
b16a JDM low miles
brand new water pump
brand new timing belt
brand new cam seals x2
brand new rear main seal
brand new head gasket
brand new ARP head studs
AZracing engine mounts polyurathane
no oil leaks
no smoke
HEAD MODS
jdm typeR head pr3-3 2months old
JDM ECU (4.200RPM VTEC) (9.800RPM REDLINE)
brand new oem HONDA valves
brand new valve seals felpro
jdm intake manifold
70mm SKUNK2 throttle body
CTR cams
typeR dual springs and retainers
port and polished exhaust side by HPS
typeR Vtec selenoid unit
H22 fuel injectors from JDM swap
custom intake pipe 4"
oem air box cleaner with custom fit K&N cone air filter
brand new valve cover gasket
after market 8.8mm ignition wires
oem dizzy
oem fuel rail
DC sports header like new 4-2-1 one piece header
DC sports test pipe
GREDDY sp2 tuner 2.1/2" exhaust
TRANSMISSION MODS
YS1 GSR JDM transmission LSD
ACT stage 3 sprung clutch less than 2k miles old
ACT pressure plate
ACT pilot bearing
JDM flywheel
brand new c/v axles less than 1k miles
JDM shift linkage
SKUNK2 short shifter dual bend
GSR front spindles
BRAKE MODS
GSR front brake upgrade
GSR master cylinder
GSR brake booster
GSR brake proportioning valve
crx SI rear disc brakes
crossdrilled / slotted rotors WILLWOOD
GSR front brake calipers
G-STOP brake line kit DOT
brand new front & rear brake pads
front upper control arms SKUNK2 CAMBER ADJUSTMENT
rear camber arms
brand new both lower ball joints TRW
brand new outer tie rods TRW
brand new inner tie rods TRW
brand new both front wheel bearings TRW
SUSPENSION MODS
KYB AGX struts like new 4way adjustable
SKUNK2 coil over springs like new
rear lower control arms CNC aluminum ( red )
front traction bars from ( DRENICACUSTOMSAUTO.COM )
big rear swaybar ( red )custom rear tie bar from ( DRENICACUSTOMSAUTO.COM )
brand new all rear bushings
brand new all front bushings
WHEELS/TIRES
brand new ROTA GT3'S
brand new front tires M/T ET street
brand new rear dunlop tires
nitro air all around
EXTERIOR MODS
brand new paint job from ( HONDA DEALER SHIP BODY SHOP )
brand new all weather strips
brand new windshield molding's
wave less body in mint cond 10/10
brand new sunroof panel
perfect working sunroof
jdm mud guards from all around
brand new front under fender liners
JDM SIR rear tail lights authentic
crx SI front lip
INTERIOR MODS
like new carpet
like new seats
like new rear cargo carpet
like new rear plastics
like new rear cargo
like new door panels
like new dash board
like new head liner
like new sunroof liner
like new A/C controller
OEM radio/tape player
like new shift boot
ice cold A/C 37*f
no tint on the windows
like new sun visors
for more info please call or check the photos close up thank you for your time
and no joy rides and no trades
also im not in a hurry to sell it
FOR THE PICTURES HERE IS THE LINK
http://www.tamparacing.com/for....html
Modified by thehondaconnection at 9:24 PM 10/30/2008
Old Oct 30, 2008 | 11:31 AM
third lobe's Avatar
a price? or starting point?
clean looking rex, GL
Old Oct 31, 2008 | 09:15 PM
Default Re: (third lobe)
bump
LSVTEC426
Sep 15, 2010 08:52 PM
darklyte
Northern California (Sales)
Aug 29, 2010 11:06 PM
Dateggy21
Nov 7, 2008 06:22 PM
TYPEcRx
Apr 11, 2008 07:32 AM
BoostinEJ1
Jan 29, 2008 03:28 PM
