sub-frame cx to si?
Old Oct 30, 2008 | 09:32 AM
joel n's Avatar
Default sub-frame cx to si?
So I auto-cross my car and do solo-sprints. My car is a 95 CX, so I have no power steering and no factory front or rear sway bars. I have a suspention technices front and rear sway bar set-up on the car, but it hangs way under the car. About 2 inchs under my cat. So i wanted to convert my front sub-frame to the SI gear so i can run the top mount style sway bar.
So, do I have to swap sub-frames or do the CX sub-frames have the spots for mounting a normal front sway bar. and then all I would have to do is get the lower control arms. And my second concer is, did the SI cars come with manual racks? and if I put the SI sub-frame in would i have to rig-up and system to mount the manual rack. i don't want to run PS.
Old Oct 30, 2008 | 10:44 AM
95vxtealhatch's Avatar
all civic subbrames have the swaybar mounts. You'll need integra radious arms though, its the complete lower control arm.
Old Oct 31, 2008 | 10:10 AM
joel n's Avatar
okay. That makes this alot easyer then swaping sub-frames.
wurmhole
May 29, 2019 06:24 PM
Notorious_T
Dec 8, 2008 05:41 PM
H22Stew
Suspension & Brakes
Apr 2, 2008 11:33 PM
Dc295kid
Suspension & Brakes
Dec 28, 2007 03:21 PM
