How to disable IAC on honda?
Old Oct 30, 2008 | 06:53 AM
foxfai's Avatar
Default How to disable IAC on honda?
I am trying to disable my fast idle valve on my integra. Is there are easy or proper way to do it? The fast idle is just to use to warm up the car, I do that anyways with or without it.
Any idea?
Old Oct 30, 2008 | 12:45 PM
Perfectionist's Avatar
Default Re: How to disable IAC on honda? (foxfai)
The fast idle valve lets the engine run well enough so it CAN warm up. How do you do it?
What are you trying to achieve or correct? IAC and FIV are separate devices AFAIK.
Old Oct 30, 2008 | 08:41 PM
jlude90's Avatar
just re-route the coolant lines and block off the FITV with a solid gasket, the IACV requires tuning to be removed on most cars
Old Oct 31, 2008 | 05:35 PM
Garrett's Avatar
With the Honda OEM ECU
only eCtune, neptune and Hondata will give you the oportuninty to completly disconnect it without a CEL code
Old Oct 31, 2008 | 09:44 PM
mmuller's Avatar
Mad Scientist
Default Re: How to disable IAC on honda? (Garrett)
take apart the fast idle and screw the white plastic screw all the way in
90BeAsTJdM
13
Jan 12, 2012 04:39 AM
ViZ
Jan 16, 2011 02:05 PM
BurgAccord95
Feb 16, 2009 06:30 PM
PSU-TEG
Mar 11, 2003 07:28 AM
Accorden
Mar 30, 2002 08:03 PM
