identifying what year this motor is. Pic Inside
Old Oct 30, 2008 | 01:05 AM
Johnny Is Bored's Avatar
Default Identifying What year this motor is. Pic Inside
I have searched and still haven't found what I was looking for. Any suggestions on identifying what year motor this is much appreciated. Buyer said it is a 96 jdm gsr. My plans are to get it bar in a 96 civic. Any suggestions would help. Thank You
Modified by Johnny Is Bored at 2:12 AM 10/30/2008
Old Oct 30, 2008 | 01:44 AM
andoxviii's Avatar
What does the block code say?
A JDM GSR would say "B18C", but so would a JDM Type-R.
Why are those wires snipped? Is this a hot motor?
Is there a VIN code?
Old Oct 30, 2008 | 02:01 AM
pdiggitydogg's Avatar
searching is great...
Look above the 3rd exhaust port, you'll see a number (9|X)...which is the year of the engine.
Add 1, and you'll know the year of the chassis it came from.
(looks like an older distributor though....)
Old Oct 30, 2008 | 03:35 AM
Default Re: (pdiggitydogg)
I know it's a jdm b18c but I'm not sure if he is telling the truth about the year of the motor. He did mention that the motor came out of a 89 civic. I asked him about the receipt and he said he is still looking for it until then I want to figure if this is really a 96 or not.
Old Oct 30, 2008 | 05:48 AM
Decaf's Avatar
VIN?
Old Oct 30, 2008 | 07:10 AM
THE GUY's Avatar
Not to be confused with "THE MAN"
I was under the impression that all JDM B series vtec motors had oil coolers as well. Every one I have purchased did, as well as all of the ones we have in the shop.
Old Oct 30, 2008 | 07:14 AM
94EG8's Avatar
Seagull Management
Default Re: (Decaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Decaf &raquo;</TD></TR><TR><TD CLASS="quote">VIN?</TD></TR></TABLE>
JDM Engines and transmissions don't have a VIN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Look above the 3rd exhaust port, you'll see a number (9|X)...which is the year of the engine.</TD></TR></TABLE>
X2
Old Oct 30, 2008 | 08:35 AM
Decaf's Avatar
wow, i totally forgot about that when i asked, good point though. and yea i thought jdm b series had the oil coollers that others didnt
Old Oct 30, 2008 | 12:57 PM
Default Re: (Decaf)
I think i would have to wait until he takes pictures of the stamp on the engine to see what year this motor is
Old Oct 30, 2008 | 02:13 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: (Johnny Is Bored)
Get a picture of the stamp on the head between/above exhaust runner 3 or 3 and 4 and look at the one to the far left.
Here is that stamp on a '96 B18C head. It says (9|5) (cast in '95 for the '96 prodution year. That is the "add 1" part pdiggitydogg is talking about).
Click on it:
Hope that helps.
Old Oct 30, 2008 | 03:09 PM
andoxviii's Avatar
I don't live in Cali so I could be entirely wrong...but I thought you couldn't BAR a JDM engine?
Old Oct 30, 2008 | 03:14 PM
sintype's Avatar
Add 1, and you'll know the year of the chassis it came from.</TD></TR></TABLE>
Old Oct 30, 2008 | 05:26 PM
94EG8's Avatar
Seagull Management
Default Re: (andoxviii)
You can but you need to add all the USDM emissions sensors, and us a USDM ECU. The block code must also be a USDM block code, IE B16A would mean USDM B16A3 or B16A2 depending on the year. Something like a DOHC ZC wont pass because there is no USDM equivalent.
Old Oct 30, 2008 | 08:44 PM
2000siturboR's Avatar
Default Re: (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">You can but you need to add all the USDM emissions sensors, and us a USDM ECU. The block code must also be a USDM block code, IE B16A would mean USDM B16A3 or B16A2 depending on the year. Something like a DOHC ZC wont pass because there is no USDM equivalent.</TD></TR></TABLE>
what about the d16a8/9 or are those jdm cant remember.
Old Oct 30, 2008 | 09:23 PM
Toy Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andoxviii &raquo;</TD></TR><TR><TD CLASS="quote">I don't live in Cali so I could be entirely wrong...but I thought you couldn't BAR a JDM engine?</TD></TR></TABLE>
I went to the smog ref in San Diego two years ago, so I have some experience with the BAR process.
A 1996 Civic is OBD2 so the motor will need to be set up for OBD2.
All B18C, B18C1, and B18C5 motors have the EXACT same bare engine block castings. Despite what the law says, the year and block code of the motor is not important to the smog ref if.............
1) You can prove you changed the pistons to USDM spec compression. JDM B18C had 10.6:1 compression. USDM B18C1 has 10.0:1 compression. And since the JDM B18C uses the same cylinder head casting as a USDM B18C1 the pistons need to be changed to yield lower compression. If you cannot prove this, then the JDM B18C code will cause you to fail.
2) The intake manifold is a USDM GSR OBD2 manifold
3) The GSR exhaust manifold or aftermarket header is USDM or CARB certified
4) The ECU is a USDM P72 OBD2 unit
5) You will need the crank angle sensor
6) You will need two O2 sensors pre and post cat
7) Set up the smog canisters, PCV valve, and vacuum lines like an OEM motor. Use a Helm's manual if needed.
When you go to the smog ref, make sure you don't display those cam gears. Adjustable cam gears will not pass visual rules. Get a used cheap stock valve cover if necessary.
Old Oct 31, 2008 | 12:04 AM
Default Re: Identifying What year this motor is. Pic Inside (Johnny Is Bored)
yes sir, good information tho. I sent him a email so hopefully held send what i asked for. Thanks
Old Oct 31, 2008 | 02:17 AM
1badteg's Avatar
shouldnt the head have a year stamped on it? my d16y8 has "99" stamped on it. its in a 99 civic ex. also check the vin.
Old Oct 31, 2008 | 09:54 PM
Default Re: Identifying What year this motor is. Pic Inside (1badteg)
I don't think jdm motors have a vin or not but this guy isn't emailing what i asked for so i guess it's a no. He was selling it for 1400 too . well whatever next time i guess. Thanks for the helps though.
Hybridguitarist
Jan 16, 2017 10:03 AM
1DayIllBFast
Apr 16, 2009 04:56 PM
divingcorners
May 7, 2006 10:28 AM
SpdFrk
Jul 16, 2003 04:17 PM
98b16hb
Apr 19, 2002 05:39 PM
