0-100 km/h=7.2 sec.Is is a good time?
Engine specs:B16A2,camshafts buddyclub stage 3,steel retainers,dual valve springs,adjustable cam gears.Stock block.Gearbox:Mfactory final drive 4.928 kit,Mfactory LSD,stage 2 fidanza clutch kit,fidanza 7.5lbs flywheel.Chipped ecu that enable reving to 9500.15'' rims.
Do you think it is a good time for my engine?
Modified by baulum at 3:32 PM 10/30/2008
Please note that i've not yet tuned,i'll be using a hondata s300.My cam gears have not been adjusted properly.So i can expect better result.
Please consider you have a hatch which is lighter than my sedan civic.
Yes,0-60mph is almost the same as 100kmh.
Anw,i'll have to try the start more times so that i may get the optimum point of rpm to launch the clutch.
Modified by baulum at 3:28 PM 10/30/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphalanos »</TD></TR><TR><TD CLASS="quote">You need to get it tuned before you go hammering on it.</TD></TR></TABLE>
what he said
what he said
From: ....................................................................................................
4 doors are not that much heavier, its actually lighter than the coupes at least the eg's are.
and the Si hatch is still heavier than the 4 doors and that does 7.5 in a 0-60 stock
10SecWannabe
Sep 15, 2002 08:13 PM
92HB_HB
Apr 17, 2002 05:49 PM
