Replaced motor now I have problems
Old Oct 29, 2008 | 09:45 PM
95GSX's Avatar
Default Replaced motor now I have problems
I replaced the motor on my moms 01 honda accord. Its a 4 cylinder. Now the car won't start. I can't shift the car out of park. I can only shift it out of park if I use the manual bypass. Also if the car is in drive I can remove the key. Anybody have any suggestions on where to start? I've double checked all the connections and they all seem fine.
Old Oct 30, 2008 | 05:28 AM
dtapia's Avatar
Default Re: Replaced motor now I have problems (95GSX)
double check it again something is disconnected
Old Oct 30, 2008 | 07:46 AM
-RedneckDave-'s Avatar
Working
What motor did you replace it with? Why did you replace the motor? Did you use the same ECU? Did you have any of these issues before the swap?
Old Oct 30, 2008 | 09:25 AM
95GSX's Avatar
I replaced it with another stock motor. I'll recheck everything tonight.
lajoyce357
May 31, 2017 09:03 AM
lsrcrvtec
Apr 8, 2007 07:01 PM
prelude1897
Feb 19, 2002 07:23 AM
