how do i pull my d sereis!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 29, 2008 | 08:30 PM
waterfordtuners's Avatar
Default how do i pull my d sereis!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sorry if this is already posted i mite b to dumb to find it but i am putting a gsr in my coupe but this is my foirst swap does anyone know what i should do first when pulling my d15b out of my 98 ex. or maby step by step instructions on what to do or a website that can give me some good advice thanks
Old Oct 29, 2008 | 08:48 PM
iamthefollower's Avatar
Default Re: how do i pull my d sereis!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (waterfordtuners)
unbolt ur shift linkages, unplug your engine harness from the firewall harness and such, unbolt your fuel line from the fuel rail, get your throttle cable off the throttle body, pop out your axles, and unbolt the 3 mounts that have it in.. make sure you have the motor hooked up to a motor puller or cherry picker.. I believe that's all, i'm thinking right off the top of my head, so if i think of anything else i'll let you know...
Old Oct 29, 2008 | 08:52 PM
lpc805EG's Avatar
Honda-Tech.com » Honda Civic/Del Sol (1992 - 2000) » NEW FAQ'S INDEX - '92-'00 CIVIC / DEL SOL
Swap Information:
GSR Into '92-'00 Civics
http://www.c-speedracing.com/h...p.php
Old Oct 29, 2008 | 08:56 PM
Default Re: how do i pull my d sereis!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (lpc805EG)
that'll be the best thing to use ... ^^^^^^^
Old Oct 29, 2008 | 08:57 PM
whereiscarmensandiego's Avatar
god u cant pull out ur d series motor and u are trying to do a swap
Old Oct 29, 2008 | 09:00 PM
Default Re: (whereiscarmensandiego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whereiscarmensandiego &raquo;</TD></TR><TR><TD CLASS="quote">god u cant pull out ur d series motor and u are trying to do a swap</TD></TR></TABLE>
Have to learn sometime or another ... Hey man you live close to cleveland Tn... don't you whereiscarmensandiego???
Old Oct 29, 2008 | 09:01 PM
Fatchance187's Avatar
D15 never game in the 6th gen EX trim. 96-00 EX came with a d16y8....
Old Oct 29, 2008 | 09:05 PM
Default Re: (Fatchance187)
could have a jdm swap in it already, the d15b vtec..
Old Oct 30, 2008 | 07:10 AM
Default Re: (iamthefollower)
thanks for all the help and no i never did a swap b4 but i wana lean and i got a riches deal on a gsr and my old car had a jdm d15b so but anyways thanks for the help guys
Old Oct 30, 2008 | 07:12 AM
Schister66's Avatar
Man U FTW
If you go by the link above and have a general sense of what to do, you'll be fine. Back in the day when i first got my GSR, i changed the clutch and had no clue what i was getting into. I basically winged it . I learned from it and now i can do it without much hassle. Good luck!
Old Oct 30, 2008 | 07:22 AM
Default Re: (Schister66)
yeah im just getting into cars and i found a clean *** coupe for cheap with a d15b i put intake intake manafold header exhaust test piep and i wasnt happy with how slow it still was so i sprayed it and ran a 15 flat in the quarter mile and then i said *** it and bout another coupew with a gsr in it but the body is ugly and its a 94 body with a 97 motor so im swaping the motors between cars and selling the 94 with my d15b in it and keeping my 98 with the gsr. it should b a funn project i have all winter bc i dont drive those cars in the winter.
Old Oct 30, 2008 | 08:50 AM
Default Re: (waterfordtuners)
Let us know where you get to on it... And Good Luck with them ...
Modified by iamthefollower at 7:48 PM 10/30/2008
Old Oct 30, 2008 | 04:51 PM
i will im sure ill run into a problem and ill post it on here thanks alot
Old Nov 1, 2008 | 11:57 AM
wow this swap is going easier than some people made it6 sound. the axels and ball joints were hard but after i got the ball joint splitter everything flopped rite out. i am pulling the d series today yesterday was the first day ever doing a swap and i got a quick question. I AM PUTTING THE D IN A 94 AND THE D IS AN OBD2 IF I JUST BUY THE OBD to OBD CONVERSION HARNESS WILL THAT WORK
Old Nov 1, 2008 | 12:03 PM
EG8AI's Avatar
investing in some type of service manual is a smart idea...
Old Nov 1, 2008 | 12:23 PM
tx_ej8_49's Avatar
I see a future post.... "Just swapped GSR and now it wont run, help!" Research, research, research. The "SEARCH" is your friend. I hope you dont have strick inspection/emissions testing in your state. Your OBDII link will no longer work running a conversion harness and this swap. You will need to search for the answers to that question.
OBDII ECU, a sensor fix, and a drive cycle
Old Nov 1, 2008 | 12:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waterfordtuners &raquo;</TD></TR><TR><TD CLASS="quote">wow this swap is going easier than some people made it6 sound. the axels and ball joints were hard but after i got the ball joint splitter everything flopped rite out. i am pulling the d series today yesterday was the first day ever doing a swap and i got a quick question. I AM PUTTING THE D IN A 94 AND THE D IS AN OBD2 IF I JUST BUY THE OBD to OBD CONVERSION HARNESS WILL THAT WORK</TD></TR></TABLE>
Yeah, it isn't hard man.. I'm glad you're doing it though... You'll have to get a z6 distributor and put all of the z6 internals in an obd2 casing (plugs and all the wires too).. that will be the only thing you'll really have to change to put the newer motor in it.. oh yeah, use an alternator for a 92-95.. i dunno if they are the same on 96-ups.. I always thought they were but someone said they weren't.. anything else just ask me.. i'll help anyway i can for you man..
Old Nov 2, 2008 | 04:55 PM
well im putting the 97 gsr into my 98 so they are both obd2 so i dont think that swap will b a problem . i bought the 94 bc it has an 97 gsr and im swaping that into my 98 and swapping my d into the 94 then selling it. all i want to do is make the d series run so i can sell it idc if it runs good just decent so it sells. the 94 has an obd2 gsr in it rite now with an obd1 harness so do u think when i drop the d series in it wont b to hard seeing as the car has a obd2 in it now. your guys help is amazing im pretty sure id still b pulling axels off if it wasnt for you guys thanks again
Old Nov 2, 2008 | 05:19 PM
Just make sure that you swap all the internals from the distributors with each other.. (plugs and all).. because if not they will be different on the plugs.. other than that everything should be ok..
JDM Jeff 95civ
Nov 9, 2010 01:54 PM
a93and07si
Oct 15, 2008 02:00 PM
LsDecepticon
Jan 12, 2008 02:22 PM
ubercerealkiller
Mar 30, 2005 03:45 AM
adictionbass
Nov 25, 2004 06:24 PM
