FS: K20 longblock / RRC / Koyo Radiator / 4.764 Final Drive / ES Bushings
Some guys I have dealt with recently:
RealEF8/cheezthis/IM ALL BOB/integra_rs91/charlesfoo/fmrprojects/Ricextacy/t0mmysays/DefiantGSR/88crxsir/jdmDAsix/tunerplayground_dc2/Crxlsturbo/emaka9/zeekbuilt
Pending:
Brand new:
$1000 - Selling these new. Pickup in San Jose/Mountain View or pay for shipping.
$350 - 306-05-1150 - Skunk2 K24A/Z Alpha Series Connecting Rods
$500 - k634m875 - Wiseco K Series 87.5MM +5CC 12.5COMP K24
Used:
Let me know if you have any questions.
Items all off a 06 Civic Si Coupe
$80 - cluster and panel I think ~15k miles
$80 - Passenger air bag
$40 - Evap canister w/sensor
Sold:
SOLD $150 - Aluminum Half Sized Radiator Koyo Honda Civic (92-00) HH080300 - Comes with a Stant Radiator Cap and a slim fan. Filler neck is a bit bent from my hood hitting the filler funnel.
SOLD $40 - EG/DC lower control arms with Energy Suspension Bushings
SOLD $40 - A/C Compressor
SOLD $600 - set of 4 225/45/15 Nitto NT-01
SOLD $450 - Koni Yellows with GC sleeves / Skunkworks 8k springs in front / Eibach 350lb springs in the rear / Ground Control extended top hats in the front
SOLD $40 Shipped - B-series Fuel rail
SOLD $400 Shipped - K-series Electric Hydraulic Steering setup details in the link below - Never got around to installing this
Electric Hydraulic Steering Pump MR2-TOYOTA 2001 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Rebuilt MR2 2000-2005 EHPS - return line fitting broken, just need to be re-attached
High Pressure hose w/fittings
Perma-Cool Compact Fluid Coolers 1007
Honda Accord 91-93, ABS module
Nice new pigtails
SOLD $70 - 2006 Civic SI Coupe OEM Rear taillights
SOLD $40 - Momo DC2 hub
SOLD $200 - Black JDM integra front bumper
SOLD $45 - USDM Rear LCAs with the bolts pictured
SOLD $40 - Stainless steel Front Brake lines. Came with my new calipers but was too lazy to install the lines when I put the calipers on. Tape is holding the washer to the bolt. Not sure what brand they are.
SOLD $200 czechmate24 - 1998 ITR P73-A03 ECU - Picked up in San Jose or I can ship if you pay.
SOLD $220 - Koyo Radiator from a RSX with a FAL slim fan
SOLD $75 - USDM ITR door panels. These are off my 98, I swapped to the JDM door panel without the tweeter holes. The fabric on one of the sides is coming off and will need to be fabric glued back on. The tweeter screw hole on the other side is broken off so the tweeter cover will also need to be glued or a bracket fabricated to keep the cover on.
SOLD $50 - 06 f/r Civic SI sway bars
SOLD $2100 - Red Volk TE37SL 15x8 5x114.3 +32
205/50/15 Bridgestone RE11 60%/40% tread. Some Brake dust on the wheels.Picked up in the Mountain View/San Jose area.
SOLD $30 - SSR WHEEL TAPER CONVERSION WASHERS - Safely run aftermarket lugs on stock wheels. Bought these and installed them on one wheel and realized long lugs look horrible with JDM 16s. http://www.speedstar-racing.com/stor...696141a2d30104
SOLD $50 Cobalt GTS Brake pads for ITR calipers ~80% meatz
SOLD $150 - Off of 2011 Civic Si Coupe. Front spindles with rotors and pads. These have ~8 miles on them. Straight from the factory driven to the shop and swapped with the setup off an older wrecked car with Brembos. Comes with everything you see in the picture.
SOLD $75 Black Wedsport lug nuts (16 lugs 4 locks)
SOLD $170 - k20z3 Oil pan with turbo return/drain -10an welded in. Went back N/A.
SOLD $700 - Recently got them steam cleaned after I picked them up. My butt is too big for these JDM seats so I want to sell these and go back to stock. Passenger seat has stock EG/DC rail and the driver side has a modified Sparco seat base with generic sliders so the seat would sit lower. Let me know if you have any questions.
SOLD ATS Ahn $100- VIS Carbon Fiber hood for JDM Integra front - I bought this to vent hot air out of the hood on the track. Did not keep it cool enough so I will just switch to a full sized radiator and put my stock hood back on. Has holes for hood pints and the holes I cut to vent it.
SOLD Xian $45 - Hawk HP+
SOLD $200 - K-Series Shifter Cables + EP3 Civic Si Idler Pulley
SOLD $600 - Gunmetal Integra Type-R rims w/Acura Centercaps
Picked these up for the stock look. Put them on and I can't really stand the stock offset/look so I want to go back to my other rims.
There are no curbs and the tires are like new. Dunlop Direzza DZ101s in 205/50/15. There are some scratches on the spokes which can be seen slightly in the picture.
SOLD $120 - Championship White ITR Hatch. No wing but has interior plastics. No Wiper hole. The JDM stickers have started to fade/peel I was going to take them off completely but never mounted the hatch. No emblem
SOLD $750 - Mugen Lowdowns, ~20k miles. Reason for selling was wanted to go lower.
SOLD GOOCH-JDM-ITR - $45 Hawk Front HP+ Brake pads - Fits stock ITR calipers. Have two sets with a lot of meat left, I switched to DTC60s so selling these.
SOLD $500 K-Pro PRB ECU, PRB has the reverse lockout
SOLD Db8_Kay $100 - JDM ITR 16" H Centercaps.
SOLD $500 JDM ITR 16" wheels - Selling them since I am now running 15s. All wheels have some curb rash, none of it done by me. All 4 wheels have Honda Center Caps.
SOLD $475 Falken Azeni RT615Ks 215/45/16 - Used for ~800 miles swapped to 15" wheels so need to sell these
SOLD $100 Momo Monte Carlo Steering Wheel. Grip is pretty thick, I swapped to a smaller wheel, will throw in fake Mugen horn button too.
SOLD AltimaXX - $400 - Rota Slipstream 5x114 15x8 +40 no tires. Used them for one trackday, got a different set on the way. Pic is before I cleaned the dust after track event. I had to shave some of the rear LCA to run these at my ride height.
SOLD $400 - Hankook Ventus R-S3 225/45/15 Used for a trackday at Thunderhill. Tires rub on my new wheels so I bought RE-11s. Need to get rid of these.
SOLD $200 - p28 ECU with hondata s100
SOLD $300 - Dunlop Direzza DZ101 205/50/15 - was going to use these as all season tires, but now decided to go with something with a bit more performance.
SOLD $350 - 4 Kumho Ecsta XS 205/50/15 - I have 800 miles on these tires. I originally bought them for my 15x7 rims then got another set of 15x8. I put them on the 15x8 and I do not like how they look. I ordered a set of Hankook Ventus R-S3 in 225/45 for my rims. Now I have no use for these tires. The Ecsta printing is still on the tires. Here is a picture when I just mounted them.
SOLD $250 - 06-11 Civic SI coupe Greddy EVO 2 exhaust, used has some scrapes but still in great condition.
SOLD $200 - 440cc injectors
SOLD $75 - HFP Side Skirts - These are off a 07 Civic Coupe, slight heat damage to the top of one but will be no problem if you repaint
SOLD $1250 - JRSC for B18c5- This supercharger kit is off a Type-R my friend picked up. Put it back to stock for California smog and he is going to keep it that way.
SOLD OmarR $100 - Blue Work RS Lug nuts - Used for about a month on my Kosei K1's then I sold the rims.
SOLD $350 - 06-11 Civic SI coupe Greddy Spectrum Elite exhaust - Dealer installed has 8 miles on it before it was pulled for something bigger.
SOLD EPSTIEK - $160 - Engineering Lug Nuts (Extended) - Anodized Black - Got these with my rims. I believe previous owner only used them for shows.
SOLD dc2-slow - $1800 - Mag Blue Volk CE28N's 16x7 +42 5x114
215/45/16 Falken Azeni RT 615s
Picked these up from the ATS guys, decided to go another route. Comes with center caps and valve stems. Looks like you will need a spacer to run the center caps in the rear.
SOLD $200 - ACT 6-puck clutch
SOLD $55 - Samco GSR GSR hoses
SOLD FMR Mike - $125 P28 ECU hondata ready
SOLD FMR Mike - $2800
This is the swap from my 98 integra GSR I totaled a while back.
I pulled the motor and put it in my current car. It is still in my car currently so I can show you that it runs before I pull it. It burns oil (either valve seals or piston rings according to people I have asked). Still runs strong and dynoed 207 whp with a mugen intake. I have since switched that intake out. I will re-dyno before I pull it out so the seller will know what they are getting.
Engine was rebuilt at 100k miles and I have since then put around 15k on it.
I am selling everything listed below since I am going K and no longer need any of this. Let me know if you have any questions or want to check out the motor.
Mods are as follows
Engine:
OEM jdm valve cover
Portflow head
Blox cams
Supertech valves
Rocket gen 2 springs/retainers
OEM jdm o/s itr pistons
ARP rod bolts/head and main studs
Ported Blox intake manifold
Hondata IM gasket
OEM ITR throttle body
Lucas 370 cc injectors
Hondata s200
Golden Eagle cam gears
Golden Eagle cam seal
AEM tru power pullies
Avid motor mounts
Hytech Header
Drivetrain
B16 tranny with JDM 4.785 fd and LSD
ACT HDSS and flywheel
Skunk2 short shifter
ES shifter bushings
Misc:
Axles
GSR shift linkage
SOLD RealEF8 - $650 - Kosei K1 silver 15x7 5x114.3 +45 offset Tires have < 500 miles on them. Azeni's are 205/50/15. They have dark Blue metal valve stems
SOLD $1200 - 07 Civic Si Tranny 15k miles no grinds.
SOLD $100 - Steering rack
SOLD $100 - Stock cat for 07 civic si
SOLD $100 - 07 civic si wing
SOLD SiClone $120 - jdm rear itr seats
SOLD cheezthis - $575 - DC2 Mugen Intake w/ lower velocity stack
SOLD $100 - Civic Si Rear Seats
SOLD IM ALL BOB - $200 - USDM ITR ECU OBII - I went OBDI for hondata so selling stock ECU. Code on ecu is p73-A03
SOLD integra_rs91 - $280 - OBX LSD - 4 drag passes k-series
SOLD $300 - Comptech Header 07 Civic SI
SOLD $30 - Visors and map light
SOLD $300 - JL Audio 8w7 in High Output Box - Hits way hard.
SOLD charlesfoo - $40 - Slim fan with a/c connector soldered on. Took out my a/c so I don't need this fan anymore. Got this generic slim fan from one of the h-t sponsers back in the day.
SOLD $500 - Honda factory performance rims 225/40zr18 w/50% goodyear eagle F1 no damage on wheels like brand new only 10k miles on rims
SOLD $400 - 87mm k24 custom 15:1 compression JE pistons w/wrist pins. 20 drag passes on these pistons.
SOLD $100 - 07 civic si steering wheel 15k mint condition w/air bag
SOLD $100 - 07 Civic Si Rear Bumper
SOLD $280 - JDM front Integra VIS hood
SOLD $65 each - BFGoodrich g-Force T/A road racing slicks 205/50/15 First come gets first pick of tires.
SOLD $50 - A/C lines / evaporator / condenser
SOLD fmrprojects - $3400 ITR motor / ITR Samco Black Hoses / Power steering stuff - put down 185/125 at DSR. 89k miles. Seller told me it had spoon cams/cam gears. Has exedy stage 1 clutch and a flywheel, used on the car for 9k miles.
SOLD Ricextacy - $200 - 4 Falken Ziex ZE-912s in 195/55/15. 90% tread, bought some rims with these tires on them and I want to go 205/50/15 so trying to sell them.
SOLD $130 - All red OEM tail lights. Bulbs included, no gaskets
SOLD $280 - Hankook Ventus R-S2 - 215/45/16
SOLD $20 - Drivers side air bag
SOLD $25 - ps reservoir
SOLD $50 - Steering wheel with air bag - the leather wrap feels loose.
SOLD t0mmysays - $10 - rear wiper plug - all OEM parts to plug the rear windshield wiper
SOLD $550 LS/Vtec motor - 2000 b16 head and a b18b1 block. Put down 160/130.
SOLD AM_H2B - $80 - Blown Zeal B2s - Two front shocks are blown and the rear bushing is cracked. Perfect for a rebuild.
SOLD $10 - ES shifter bushings - black for integra
SOLD $60 - Walbro (whinebro) 255LPH fuel pump - model number GSS342, has the little bag thing and the hose, used on a 98 integra.
SOLD $100 - Falken Ziex ZE512 205/55/16 - Nice tires for everyday driving but I upgraded to azenis rt-615s.
SOLD $20 - Vibrant J-SPEC Header Outlet Flange Kit
SOLD b18cEK - $90 - black Apexi VAFC II - put down 172 hp with the vafc, switched out to hondata.
SOLD TodaCivic - $100 - C's Short Shifter - Single bend, some of the paint is chipping off since my shift boot rubbed it off.
SOLD $20 - Stock GSR rear sway bar - Bushings and brackets included.
SOLD $200 - Blox Front / Rear Camber Kit - Sold as a pair only
SOLD $40 - Heater Core - I cut the two hoses to get it out of the car.
SOLD $60 - Sunroof
SOLD $25 - Cargo cover board for an integra hatch
SOLD $50 - Rear Leather Seats
SOLD $180 - Black integra dash center console - Comes with all the random steering column pieces, glove box.
SOLD 88crxsir - $60 - Black carpet, cut in 3 places to get it out of the car. Carpet and floormats together for $110.
SOLD DefiantGSR - $100 - ITR rear sway bar + BSQ subframe kit - no pics since it is still on the car
SOLD $300 - OEM JDM 4-1 Header, OEM upper heatshield, Fastline lower skid plate
SOLD $300 - carsound cat, RS*R exhaust
SOLD $400 - 4 K1's 15x7 +45 Offset - One wheel is scratched from where I hit a wall, the air has leaked out of the damaged wheel and will need to be repaired.
SOLD $50 - Black floor mats. Anchor included, see pic above for anchor. Wear can be seen in the pics. Got these back in 2002 when I got my car.
SOLD that180guy - $75 - Brake master cylinder / Brake booster
SOLD $300 - GSR leather seats/a4 HIDs
SOLD $45 - rays lugs
SOLD $35 - mirrors
SOLD $400 - koni/gc 400/500 f/r rates
SOLD $300 - oem kit
SOLD $50 - rear bumper
SOLD $100 - comptech intake
SOLD $35 - trunk mat
SOLD asc - $60 - rs bezels door panels
SOLD $120 - plastic interior / rear belts
SOLD tegracer19 - $200 - spoon f/r bars
SOLD $35 - samco gsr radiator hoses
SOLD $70 - passenger door
SOLD $40 - fender liners
SOLD $40 - driver door
SOLD $180 - kenwood hu / ipod / ipod adapter
SOLD $60 - alpine amp
SOLD $10 - pass turn signal
SOLD $15 - radiator overflow
SOLD $60 - rear seats
SOLD $100 - sunroof / heater core
SOLD $40 - spoon shift ****
SOLD $40 - itr flywheel
SOLD $100 - C's short shifter
Pending:
Brand new:
Used:
Sold:
Nice new pigtails
Mods are as follows
Engine:
OEM jdm valve cover
Portflow head
Blox cams
Supertech valves
Hondata IM gasket
Hondata s200
Avid motor mounts
Hytech Header
Drivetrain
ES shifter bushings
Misc:
Axles
GSR shift linkage
SOLD $60 - Sunroof
SOLD $35 - mirrors
SOLD $300 - oem kit
How much would u sell them seperately if u do find a buyers for different parts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project-Honda »</TD></TR><TR><TD CLASS="quote">i might at those rear seats, their for a coupe right?</TD></TR></TABLE>
Yea from a 2 door. If BIGGIDYBOB flakes I'll save em for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai »</TD></TR><TR><TD CLASS="quote">I don't have a buyer for the rest of your setup but I am interested in your muffler/axleback.</TD></TR></TABLE>
Ya, don't think anyone will just buy the piping, sorry.
Anyone interested in just the rims? Would be easier to fix the damaged rim this way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIGGIDYBOB »</TD></TR><TR><TD CLASS="quote">still down to take those seats. Just gotta meet up somewhere</TD></TR></TABLE>
Yea, don't know when I will make it back up to the SF area, you ever come down to SJ?
