chiping p75 plese help me
Old Oct 29, 2008 | 07:13 PM
1sicef9's Avatar
Default chiping p75 plese help me
ok im chiping a p75 i got the vtec conversion kit but i did not give any directions on were to put the parts .....please help
i got it from moates.net
Old Oct 30, 2008 | 12:10 PM
lightning's Avatar
Default Re: chiping p75 plese help me (1sicef9)
Go back to moates.net If your board is a "1720" go here: http://www.moates.net/product_...d=154 Right below the 2 pictures you will see the parts list:
1720:
Q26 D1423 NPN Transistor
C60 1uF Capacitor
IC14 SK5151 High Side Switch
J10 0 Ohm Resistor
R67 820 Ohm Resistor
RM11 RM11 Replacement Kit
D11 1N4002 Clamping Diode
The parts location is the matching location on the board. ie. J10 (0 ohm resistor)goes on J10 position on the board
If your ecu is different then use one of their corresponding kits. Above is just an example.
Rigginit
Engine Management and Tuning
Jan 7, 2010 03:28 PM
itr1235
May 26, 2007 09:31 PM
spike
Feb 10, 2003 04:07 PM
EiksITR
Jun 2, 2002 03:39 PM
