Torqued down caps. motor won't turn
Old Oct 29, 2008 | 05:09 PM
UserX826's Avatar
Default Torqued down caps. motor won't turn
Just rebuilt a motor, didn't torque down the rod connector caps.. before i realized that, the motor was turning, cranking, and running. I just pulled off the oil pan and torqued everything down. Put everything back on and now the motor won't turn over. WTF?
Old Oct 29, 2008 | 05:18 PM
1992Si's Avatar
Can you spin the engine by hand ?
Is the battery fully charged?
You may have spun a rod bearing and then tighten the spun bearing into the crank.
good luck
Old Oct 29, 2008 | 05:22 PM
UserX826's Avatar
Can't turn it by hand, the crank bolt actually just comes loose now.
It's being jumped off.
Possible that i just torqued it too much and the rods can't spin around the crank?
Old Oct 29, 2008 | 05:24 PM
1992Si's Avatar
I'm guessing the oil pan is back on?
What did you torque them to?
Old Oct 29, 2008 | 07:50 PM
UserX826's Avatar
yeah it's back on. Haynes says torque them to... 23 i think? but the numbers on the wrench don't go that low. so i was estimating
Old Oct 29, 2008 | 08:29 PM
mikehawk's Avatar
Default Re: (UserX826)
you dont estimate an engine rebuild
Old Oct 29, 2008 | 10:00 PM
scbmx87's Avatar
Default Re: (mikehawk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikehawk &raquo;</TD></TR><TR><TD CLASS="quote">you dont estimate an engine rebuild </TD></TR></TABLE>
x2
My guess is you slammed a rod bearing into the crank and mashed it all up.
Old Oct 30, 2008 | 11:55 AM
UserX826's Avatar
no no.. you guys aren't following.. after i torqued it down nothing moves.. can't slam anything into anything because the crank doesn't move
Old Oct 30, 2008 | 11:58 AM
redrim's Avatar
no...your not fallowing.the bearing could be all fugged up.then you tightened it to the crank.its scared and now wone move.its like chewing up a bolt,then treading into a nut and trying to take it out.its gunna be jammed up.your bottom end is most likely ruined,and will need to be machined all over again
Old Oct 30, 2008 | 12:00 PM
davefromPA's Avatar
no you my friend are not following...
you guess on tightening down an engine rebuild. they are saying you "slammed" (as in tightened to much) a brearing into the crank making it impossible to move.
Old Oct 30, 2008 | 02:06 PM
1992Si's Avatar
OP, next time, make a mental note to self, rotate the crank after you tighten each cap.
Oh I'm sorry, make that after you torque each cap. You may want to tighten everything evenly in steps, making sure the crank rotates.
Old Oct 30, 2008 | 03:20 PM
Cjdcivic's Avatar
Default Re: (1992Si)
x2.... never should you torque down main or rod caps and not test to see if the crank moves. Test it every time you torque something.
Old Oct 30, 2008 | 04:00 PM
1992Si's Avatar
Default Re: (Cjdcivic)
Great, now we tell him.
em1kiddo
Dec 24, 2011 02:22 PM
si90rex
Oct 20, 2010 04:48 AM
hiphop23j
Mar 11, 2008 05:17 AM
b20vtech
27
Feb 27, 2008 10:38 PM
the.hamburglar
Nov 30, 2005 03:16 PM
