Stripped oil drain plug ????? (help needed)
Old Jul 29, 2002 | 10:13 PM
ShiftDown's Avatar
Default Stripped oil drain plug ????? (help needed)
Ok I just changed the oil the other day on my geezer and I think my oil drain plug is stripped. This is what happened; I was tightening the drain plug bolt (yes, I was using a torque wrench set to 33lbs) and I noticed that it would tighten to a certain point and then I can feel the thread jump back and it would loosen slightly.... this would repeat itself if I kept trying to tighten so I could never get to tighten to 33lbs.
I needed my car so I left it as tight as it would go before jumping back and put in the oil. Its not leaking that much but nevertheless it is leaking about 1 drop every 5 minutes. What do I do to fix this problem?? Do I need a new drain plug bolt or would the thread on my oil pan be the problem??? Any help is appreciated
David
Old Jul 29, 2002 | 10:19 PM
baonest's Avatar
Default Re: Stripped oil drain plug ????? (Oki_Doki)
check the plug.. if the threads are phucked then u need new screw.. but also check the pan cuz them might be messed up too..
Old Jul 29, 2002 | 11:34 PM
bullz's Avatar
Default Re: Stripped oil drain plug ????? (baonest)
Funny thing is that I almost rounded off the bolt today
Old Jul 30, 2002 | 01:02 AM
GSRaCeRbOI's Avatar
look at the bolt head and see if its rounded, the threads on the bolt AND the oil pan and see where your problem is.. if its the drain plug then just go get a new drain plug.. shouldn't cost that much.. if its the threads in your drain pan/oil pan..then its going to cost you some = (... its probably the drain plug though... I bought one a week or 2 ago for under $5...
if you have trouble removing the rounded bolt w/ a socket or it slips or whatever and won't come off.. get a vise grip and grip on it and turn.. or get a crescent wrench (is that what its called?.. its a big wrench w/ angled jaws that grip.. kinda like a giant needle nose plier w/ angled tip)...grip on the bolt and turn to loosen and it should come off...
Old Jul 30, 2002 | 01:12 AM
Mr. Softee's Avatar
Default Re: Stripped oil drain plug ????? (GSRaCeRbOI)
use vice grips
Old Jul 30, 2002 | 08:30 AM
Rtzx9r's Avatar
GDD 1%
Default Re: Stripped oil drain plug ????? (94goldjungsr)
33 ft lbs is wayyyyyy to tight for that bolt
Old Jul 30, 2002 | 08:44 AM
96IntegraLS4DR's Avatar
My 90 Teg was the same thing.
Turned out the thread on the oil pan was stripped.
After putting in new oil pan, I also installed http://www.fumotovalve.com/ as a
preventative measure.
Old Jul 30, 2002 | 09:47 AM
WOTTEG's Avatar
Default Re: Stripped oil drain plug ????? (Rtzx9r)
Rtzx9r: 33 ft/lbs is factory spec on B18B's and C's.
You are using a new aluminum washer right?
Old Jul 30, 2002 | 09:55 AM
SJR's Avatar
SJR
Default Re: Stripped oil drain plug ????? (Teken)
if the oil pan threads are messed up, you can repair it...
Go buy some Heli-coil of the correct thread diameter and step, remove the oil pan, drill out the old messed up thread, tap the hole, insert the heli-coil, and there you go, a brand-new thread in the old oil pan.
Heli-coil is kinda expensive (depending on size) but still cheaper than a new oil pan.
And go buy a new drain plug as well.
Old Jul 30, 2002 | 04:20 PM
stumpyf4's Avatar
Default Re: Stripped oil drain plug ????? (SJR)
You can go to Jiffy Lube, they have an assortment of piggy back drain plugs. It's a bolt with a smaller bolt inside. The larger size is permanently installed into the pan and you use the smaller one to drain the oil.
Other wise you could just buy the next size up in bolts and retap the pan to fit it.
Marty.
Old Jul 30, 2002 | 04:23 PM
uNF$@#!'s Avatar
Default Re: Stripped oil drain plug ????? (stumpyf4)
tap and die set can rethread stripped threadding.
Old Jul 30, 2002 | 08:43 PM
RedGSR's Avatar
Default Re: Stripped oil drain plug ????? (96IntegraLS4DR)
http://www.fumotovalve.com/ is interesting. But I am afraid that a rock might hit the lever to the drain position. I would give it a try if it has a better locking mechanism.
Old Jul 30, 2002 | 11:44 PM
Cramerox's Avatar
Default Re: Stripped oil drain plug ????? (RedGSR)
doesnt seem like all the oil would drain out since the thread of that thing is in the pan. a good amount of oil might not drain out.
supadupafast
Aug 11, 2013 09:57 AM
jyacoba2009
25
Sep 15, 2010 07:24 AM
WTFProtein
May 12, 2010 04:08 AM
Buktheng
Aug 31, 2007 05:05 PM
Nos4R2
Jul 1, 2003 06:09 AM
