CRX CF hood fitment
Old Oct 29, 2008 | 04:43 PM
Dkahn18's Avatar
Default CRX CF hood fitment
I installed a CF hood on my rex a while back, Oem style, and the the drivers side is "propped up" like a half inch more then the passenger side, i cant find what its hitting on, anyone have any ideas? ( 1990 si if it matters)
Old Oct 29, 2008 | 04:49 PM
sgallagher's Avatar
Default Re: CRX CF hood fitment (Dkahn18)
May be the mold of your hood. I have seen many CF hoods not fit perfect. Sorry man sounds like your SOL.
Old Oct 29, 2008 | 05:21 PM
Dkahn18's Avatar
Default Re: CRX CF hood fitment (sgallagher)
i see i see, i could always put a rubber stopper under the other side^^ and prop it up a little like i said its around 1/2 inch
Old Oct 29, 2008 | 06:40 PM
therotaryrocket's Avatar
Basically all the panels that bolt on are also adjustable to a certain degree. Try loosening the hood hinge bolts, but leave them snug, then close the hood (with no striker installed!) until everything lines up properly. Now just tighten the bolts up and reinstall the striker (which may have changed position now).
Also, as mentioned up there ^^ check out the rubber bump stop. If nothing else you can make it look a lot better, you can adjust the fender upward some, and the opposite side of the hood and fender downwards to help balance them out.
If there is not enough adjustment, say for example in the hood hinge bolts, then you can enlarge the holes with a dremel or grinder or something, just slot them in the direction you need to go. Also you can sometimes bend some metal, say the arms of the hinges, smack it with a hammer and a block of wood or bend it in a vice or something.
GL
Old Oct 29, 2008 | 07:16 PM
H22Ej1's Avatar
Shenanigans
i have the exact same issue with my 4dr ef ..its just a bad mold warping the hood i spaced the rear of the hood up slightly and put a rubber hood stop on the low side and now it sits flush
Dkahn18
Paint and Body
Nov 5, 2008 04:36 PM
hondaPINK
Aug 15, 2007 05:40 PM
emooheo
18
Dec 20, 2006 07:12 PM
alias 33
Jul 21, 2004 03:23 PM
RiceRacist
Nov 12, 2003 11:18 AM
