COOLENT HELP!
Old Oct 29, 2008 | 11:22 AM
Unseen Racer's Avatar
Default COOLENT HELP!
about a month ago i installed a water temp gauge and i cut a piece of the upper coolant house so i can fit the temp adapter.
i THINK that an air pocket got inside since when i cut the piece of coolent fell out.
how can i bleed my coolant and put new one in so i wont have the air pocket(just incase i do have an air pocket). i know that on the bottom of the rediator is the coolant plug that drains the coolant.
but do i just put new coolant in while the engine is running?
or when the engine is off?
Old Oct 29, 2008 | 11:53 AM
90Rexx's Avatar
Default Re: COOLENT HELP! (Unseen Racer)
you have a bleeder valve on your upper radiator hose neck on your head. open the valve and let your car idle....once coolant starts coming out close it ;-)
Old Oct 29, 2008 | 12:03 PM
Default Re: COOLENT HELP! (90Rexx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Rexx &raquo;</TD></TR><TR><TD CLASS="quote">you have a bleeder valve on your upper radiator hose neck on your head. open the valve and let your car idle....once coolant starts coming out close it ;-)</TD></TR></TABLE>
do i open it while the car is on idle?
or when its off?
Old Oct 29, 2008 | 12:35 PM
SDHonda153's Avatar
When its Idling
Old Oct 29, 2008 | 09:27 PM
Default Re: COOLENT HELP! (honda.lioness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda.lioness &raquo;</TD></TR><TR><TD CLASS="quote">The directions from the 95 Civic manual at http://ww1.honda.co.uk/car/owner/workshop.html explain what to do. Go to the Engine, Cooling section.
I think the step most likely to trip a person up is where it says to wait for the radiator fan to come on twice. This typically takes 20-45 minutes, depending on ambient temperature.</TD></TR></TABLE>
is it the same for a 96 civic??
Old Oct 29, 2008 | 10:48 PM
mattyv's Avatar
honestly. i just open the radiator cap and start the car. keep filling it until it stops bubbling and put the cap back on. never failed me
Old Oct 30, 2008 | 06:58 AM
tegboy 195's Avatar
Default Re: (mattyv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattyv &raquo;</TD></TR><TR><TD CLASS="quote">honestly. i just open the radiator cap and start the car. keep filling it until it stops bubbling and put the cap back on. never failed me</TD></TR></TABLE>
thats what i've always done
willfly
Dec 30, 2013 09:44 PM
SPOON_BeIgHtEeNsEe
Honda CR-V & Element
Nov 30, 2010 01:54 PM
john457
15
Dec 21, 2005 05:36 PM
Jet Black
Jan 17, 2004 08:41 AM
glock
10
Aug 8, 2002 06:21 AM
